Hi i installed the car video player, and it works good, until i turn on the car lights , then the car video player start to flicker and the screen gets bad, what can i do to fix it?
WIFI connection method:
1. Switch the power button to turn on, then long press the play key until the blue light on(30 seconds later, blue indicator light start flickering, then the clock camera is turned on , and then red indicator light will flickering, which means the clock camera WIFI signal is opened)
2. turn on the WIFI on your smart phone . Run APP software that you have downloaded and installed
If it would be a video card driver problem, you could still fix it, but if would be the video card itself, then you need to replace it.
Here what you can try.
- If you have an external monitor, connect it to your laptop. Observe if you will get the same flickering screen.
- If yes, download and install an updated video card driver from Toshiba website. Make sure that it is compatible for your Operating System (Linux, XP, Vista or Windows 7) and system model.
***NOTE: If updating the video card driver will not resolve the issue, surely the video card is failing. It needs to be replaced.
- If no, the problem is with the LCD of the laptop. Consult a professional technician to help you check LCD cable, LCD inverter and LCD itself.
- If you don't have any external monitor, go to the BIOS setup (either pressing F2..(it depends on what key was designed for it)..at the manufacturer's logo). If the screen will flicker at the BIOS setup screen, consult a professional technician to help you check LCD components.
Did you say the the video output flickers on and off when you connect an external monitor to the video output.
If the inverter is faulty this would not affect the video output and the external monitor would not flicker but if the external monitor flickers it would point to a video card problem.
hold down the setup button until the menu comes up. press the '6' button. press the '6' button until "expand box" is hi-lighted. press 'up/>>l' button.
worked for me. good luck.
Those player are very low price and quility, about $25 each. I would go with an indash touchscreen unit from Pioneer or Kenwood and send signal to the flipdown screen.
I would suggest trying another monitor to rule out your PC or monitor card.
I would also check the video settings on the PC.
Then assuming your cable/connector and video card are okay, it sounds like a lamp or lamp driver (a.k.a. ballast or inverter) issue.
In other words, an internal issue that probably needs component-level troubleshooting.
