Individual SlideShow Expressions Logo
Posted on Aug 17, 2010
Hi there when i log into slide show expressions i get a ' black/blank window right in the middle of the title page. pse HELP i need to remove this window
Anonymous
Level 1:
Scholar:
New Friend:
  • Contributor 45 Answers
  • Posted on Nov 07, 2010
Anonymous
Contributor
Level 1:
Scholar:
New Friend:
Answers
45
Questions
Helped
15493
Points
61
This is quite normal. It just means that no project is opened up yet. You need to either create a new project / slide show or open an existing one. The little black window in the middle is only "reserving" the spot where the chapter icon will appear on your menu page once you've newly created a chapter or slide show. Later on, the little black window will be replaced with one showing one of the photos you have inserted - you can choose which photo you want to display as chapter icon. You can also alter the position of these chapter icons in the "Design" tab.
Gateway modem
http://support.gateway.com/us/en/s/PC/DX/2906093R/2906093Rnv.shtml
1) FOLLOW Anti-Static Precautions
Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
Relieve your body of Static electricity BEFORE reaching inside your computer, and BEFORE taking any new parts out of their anti-static bags, or cartons.
Computer on a table, computer Unplugged from power, computer case open;
TOUCH an unpainted surface, of the metal frame of the open computer case.
This action will relieve your body of Static.
IF you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
2) Open the computer case;
Click on User Guides in the Gateway link above.
In the list click on -
8513028 - Gateway Hardware Reference Guide
[ This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name it may take up to 30 seconds, before the first page comes up ]
(Note* First page is Black, and blank. Second page is blank, and White)
Hover your mouse cursor on the bottom/middle of the page. The ghosted out navigation guide will appear. Click on the PDF icon all the way to the Right. (Show Adobe Reader Toolbar)
Use the Plus ( + ) icon at the top of the PDF file, to increase the view size.
Click on the Minus ( - ) icon to decrease the view size.
Use the Down Arrow at the top of the PDF file to go to Page 41.
(PDF reader page number. Actual manual page is 35)
Loosen the two Thumbscrews, pull back on the formed fingerpull, and remove the left Side Panel. (Pulls back so far, then tilts out to remove)
[I find it best to remove all cables beforehand, then put a soft cloth on the table, and lay the computer on it's side. Much easier to access hardware components on the motherboard ]
Going back to the main support page, click on Components.
In the list, and under the bold black subheading - Motherboards,
click on -
4006273R - MSI Nvidia MCP73PV Motherboard
The two long White slots shown at the bottom of the motherboard, are PCI expansion slots.
An Ethernet card can be plugged in here.
(PCI Ethernet Card example, {10/100/1000},
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=771339&CatId=1175
Notice above the two long white PCI slots, that there is a longer Black expansion slot.
This is a PCI-Express x16 slot, and is ONLY used for a graphics card.
The small White slot above it is a PCI-Express x1 slot.
It can also be used for an Ethernet Card.
A PCI-Express x1 Ethernet Card,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2197688&CatId=2380
A closer look at a;
1) PCI expansion slot,
http://support.gateway.com/s/MOTHERBD/MSI/4006273R/4006273Rmvr18.shtml
2) PCI-Express x1 expansion slot,
[ Just for reference a PCI-Express x16 expansion slot,
http://support.gateway.com/s/MOTHERBD/MSI/4006273R/4006273Rmvr19.shtml
When removing a PCI-Express graphics card, the tab lock on the end is gently depressed ]
Adding or replacing an expansion card, starts at the bottom of Page 54. (PDF file page. Actual manual page is 48)
The metal slot covers at the back of the computer case metal frame, are Expansion Slot Covers.
Remove the one covering the slot you need, by removing it's Philips head screw.
Note that the slots in the metal frame for the expansion cards, does not line up with the expansion slots on the motherboard. They are one over.
Insert the Ethernet Card straight down in the expansion slot, lining up the Locating Notches at the bottom of the Ethernet Card, with the Locating Lugs down in the bottom of the expansion slot.
You also have to slide the 'tang' at the bottom of the Ethernet Card's metal bracket, down into a space in-between the outside metal framework of the computer case.
Plus line up the bracket's locating hole, (half-moon?), with a short dowel in the metal framework.
All of the above will become apparent once you start to install the Ethernet Card.
One last procedure is to Physically push down on each Ram Memory module ('Stick'), and also make sure the Locks at each end, are up, and in place.
Ram Memory gets bumped real easy. Better to check before going on. (Visual inspection will Not do. You have to physically check)
Card plugged in, and fastened down, close the computer case.
Reattach all cables if you disconnected them.
Plug the computer back into power.
Plug the Ethernet cable into the Ethernet Card.
WAIT 1 minute, turn the computer on.
For additional questions please post in a Comment.
Regards,
joecoolvette
1helpful
2answers
I need to know how to have File Edit Help Etc along the top of my page
I assume that you have Internet Explorer?
If so - try to press ALT - the toolbar should now appear.
Cheers,
F1X3R3R
1helpful
2answers
How do I remove a tumbnail from a photo?
Once you've added you're photos, you can set a different photo to act as thumbnail (the programme automatically chooses the first photo/slide, indicated by a little green ticked box sign).
To change the thumbnail to a different photo, highlight the photo you want as thumbnail by clicking it - the frame will change to yellow - and then click on the green ticked box command ("Set Thumbnail") at the top of the window.
You cannot alltogether delete the thumbnail, because every slide show you create needs to have a thumbnail to link the slide show to the menu screen at the start of your DVD. So, on your menu screen there will always be at least one thumbnail. (The black thumbnail that appears in the middle of your screen when you first open the programme, is a "place holder". It needs to be there and it cannot be deleted. Once you've created a slide show, it will be replaced with the photo you have chosen to be the thumbnail. Every time you create a new slide show, a new thumbnail will be added to your menu screen. The position of thumbnails can be changed, using the second ("Edit") Tab.
You will find a User's Guide on the install disc. It can be accessed by inserting the install disc and clicking on the relevant link, or you can right click on your CD/DVD drive (in "My Computer") and then click on "Explore" to look for it on the install disc - it's a pdf file.
1helpful
The font size suddenly reduced, to too small to
hi
Please try the following
Right click in the middle of the screen, left click on properties, a window entitled dispaly properties will come up, click on the tab that says settings. in this window there will be a slider bar with the title screen resolution slide to the left to nake smaller, slide to the right to make bigger
YAHOO MAIL PROBLEM
Most of the people having the same problem this week full the problem is You can log into your eMail account but the inbox-page does not load properly and turns up completely blank.
It is still possible to access your eMails, even though in a very minimalistic way.
Log in and then use the following link. It's a text-based inbox, yet better than nothing:
http://us.m.yahoo.com/p/mail
Hope that helps and keep your fingers crossed that yahoo! will fix this problem soon
Oct 06, 2009 • Yahoo Mail
New browser windows open to the right of the previous one.
Instead of opening a new IE browser for each site, try using the Tabs at the top (blank square next to the Website title). (see below)
You can also Right-Click on links on web pages and select "Open Link in New Tab". This should also help your computer run better as opening new browser windows uses more memory.
Dark burn in? at top and bottom of screen. TV is only 16m old.
PixelProtector is a tool for fixing stuck pixels, removing screen burn, correctly calibrating screens for optimal performance and gaining the best possible picture. Any large screen television is an investment. Poor set-up and calibration can degrade the quality of a television's image and severely threaten the life of the screen.
If you own a large plasma or LCD television with a DVD player and want to achieve optimum performance, PixelProtector is highly recommended.
3 ways to remove burn-in
1. PixelProtector for Removing Screen Burn.
2. downloading a free program called JScreenFix
3.
Screen Burn Removal Using Your PC.
If you can hook your PC up to your screen burnt TV try this. Create a folder in 'My Documents' called 'Screen Burn'. I'm not joking keep reading. Now open up a picture editor like 'paint' available on all Windows PC's. When you run 'Paint' a blank white document is what you should have in front of you. That is exactly what you need. Select File – Save as and name your picture 'white'. Be sure to save it in the folder you just created.
Next you need to click on the 'black' section of the colour pallet at the bottom of the 'Paint' window. After you have selected black click on the 'Fill' icon (a tipped paint pot) on the left. Now simply click in the middle of your white picture and it should become totally black. Select File – Save as and name you picture 'black'. Again be sure to save it in the folder called 'Screen Burn'. You don't need paint any more so you can shut it down.
Now right click on the Windows desktop an select Properties – Screen Saver and using the drop down list select 'My Pictures Slide Show'. Now to configure the slide show. Click Settings and configure as follows. Slide the bar to 'More' so that pictures change frequently. Slide the next bar to 'Larger' so pictures fill the whole screen. Now click the 'browse' button and find the folder you made called 'Screen Burn'. In the next set of options:- Check 'Stretch Small Pictures', Un-check 'Show File Names', Check 'Use Screen Transitions' and finally un-check 'Allow Scrolling Through Pictures With The Keyboard'. Save the options.
Different versions of Windows might have slightly different configuration options but as long as the result is a completely filled (no borders), alternating white and black screen with no writing then it will probably help.
Now set your screen saver to 1 minute and leave the keyboard and mouse well alone.
As with the 'snow' and 'signal pattern' leave this for a while to see some results. If you use your TV for the PC then it might be a good idea to use this as your regular screen saver and run it frequently.
The only snag is the headache of connecting the PC up and the fact that removal technique will not be running at your screens native resolution.
Here are some more resources:- PixelProtector Screen Burn Removal and our old screen burn home page
Hi, outlook express 6: when open is white blank screen with only toolbar at top a grey bar and an orange search bar ?? when open it recieves msgs but i cant see any thing. Help would be much apreciated.
I would suggest an Outlook Express Reinstall after you back up your address book and message list. If nothing is of importance just resinstall it because backing up can be problematic with OE being partially functional.
Reinstall OE6
 You need your windows CD and you must be logged on as Administrator or as a member of the Administrators group in order to perform this procedure.
  1. Click Start , click Run , and then type the following command:
%systemroot%inf
ie - "c:windowsinf" - no quotes
  1. Click OK to open the INF folder.
  2. Locate the file MSOE50.inf .
Right-click the file, and then click Install . This will reinstall the files that Outlook Express needs to proceed normally.
It will ask you to put your windows XP cd in the drive
James Mac
3answers
"Skip Blank Page" Set to 0.1% Yet still skips pages with footers and headers
We have the same problem where I work. We use a black texta and draw a line down the middle of the page. This gives the scanner a point to pick up apart from the minimal text at the top. However, this will only work if you are happy to have a line on your scanned document!
Top Individual Computers & Internet Experts
k24674
ADMIN Andrew
ADMIN Andrew
Don A
Don A
Are you an Individual Computer and Internet Expert? Answer questions, earn points and help others
