Question about Kenneth Cole KC3434 Wrist Watch
How to open the back of Kenneth Cole KC3434 watch to change the battery?
  • 831 Answers
BASIC WATCH BATTERY CHANGE
Get a replacement battery for your watch. Some watches have the battery information stamped on the back plate. If yours doesn't, you'll have to wait until you've removed the old battery to see what kind of replacement watch battery you'll need.
Lay your watch face down on a non-scratching, non-skid surface. It may help to clamp the watch to the surface.
Remove the back from the watch. You might be able to pry it off with your fingernail, but you'll probably need a stiff, thin tool like a knife or screwdriver. You can also buy watch repair kits, which have the perfect tools for the job. Check the watch back for a small notch to insert your tool, but not all watches have these.
Remove the battery from the watch once the back is off. You might need to tip the watch over to let the battery fall out.
Insert the new watch battery into the proper space, first double-checking its size against the old battery to make sure it will fit. Press lightly into place.
Replace the back on your watch. Make sure you press firmly to get the back seated snugly.
If this doesnt work, then take to a local jeweler/watchmaker who is equipped with the right tools to assist you.
Best regards.
Posted on Aug 17, 2010
Testimonial: " thank you very much!!"
SOURCE:
What size battery does a kenneth cole watch model # 9172 use
Take your Kenneth Cole watch to a jeweler who will open it, identify the battery type, and perhaps replace it for a reasonable sum.
Sep 22, 2017 | Kenneth Cole Watches
Battery size for Kenneth Cole KC3679 watch
Take your Kenneth Cole watch to a jeweler who will open it, identify the battery type, and perhaps install a replacement.
Apr 17, 2017 | Kenneth Cole Watches
Manual kenneth cole for watch ul 1181 where can i get the manual
i am not understanding ......
you need Manuel for replacing battery ?
or
you need Manuel for setting up digital part of your watch ?
Jul 28, 2014 | Kenneth Cole Unlisted Chronograph Watch
How to change the battery in a kenneth cole 3504 watch
you have to open caseback, inside close to the battery see one tiny metal piece pressing & holding battery, you need a tiny pin to pry that metal piece battery will come out put new battery on then press VERY GENTLY 9k=
May 13, 2014 | Kenneth Cole Reaction KC3504 Watch for Men
How do I open Kenneth Cole watch KC 3567 to replace battery?
If you don't have the proper tools I recommend that you not do this yourself. You could scratch the case or damage the movement if you don't know what you're doing. If it's a water resistant watch the gasket also needs to be replaced once it is opened. DO NOT reuse a gasket! For about $8 any watch or jewelry2_bing.gif store can change the battery and renew the gasket for you.
Apr 11, 2010 | Kenneth Cole 1213 Wrist Watch
How do I replace a battery on a kenneth cole watch and square fossil watch
Open watch case back, then release the metal contact covering the battery. Memorize battery's polarity (+ up and - down), then take the battery out. Memorize the combination of letters and numbers on battery (should be something like: CR 3216 or similar). Make does not matter - Seiko is as good as Maxell, Panasonic2_bing.gif and other reputable makes. Buy new battery with identical combination of letters and numbers and put in your watch. Replace back contact, gasket and case back. Set your watch and enjoy. Rate me, please.
Feb 28, 2010 | Kenneth Cole KC4232 Wrist Watch
Kenneth cole reaction KC1408 changing battery problem
You have to take the back off. If it has about 6 slots around the back, then it screws off. If it's flat, then you can pry it open. If you pry it open, it,s very difficult to get it back on all the way. You may have to get some tools, or go to a repair shop.
Mar 02, 2009 | Kenneth Cole Watches
Kenneth Cole Watch KC3493... getting the back off
sometimes watches must be opened from the crystal side
Nov 27, 2008 | Watches
Kenneth Cole KC3434 Wrist Watch Logo
6,216 people viewed this question
Top Kenneth Cole Watches Experts
Arturs Kalnins
Arturs Kalnins
Norman Worley
Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
