All 4 burners stay on high
I did not receive instructions with my G E Profile cook top Model No. 80030750434). There is a build up on the elements which I am having problems removing. Should the top be scraped while the stove is hot or cold? What is the best cleaning product to use?
SOURCE: GE profile performance electric cook
Confirm there is 240 VAC powering the unit (make sure a breaker has not tripped or a fuse blown.).
Did the burners ever produce enough heat?
If yes, then we can look deeper. If no, then the burners may not be adequate for your cooking style. Burners are like light bulbs. A 60 watt bulb will put out more light than a 40 watt bulb. A 100 watt bulb will put out more light than a 60.
Typically, a small burner will provide less cooking heat than a large burner.
SOURCE: Counter top stove burner won't light
Hi, You asked a very generic question but I will try to give you a good answer. If the pilot is good and you can light the burner with a match, (this checks everything else) then the most common problem would be the burner holes in front of the pilot are clogged. When cool, remove the burner and inspect the holes, any debris needs to be removed, a bent paper clip works really well. Compressed air helps as well. If there is a tube to the pilot make sure it is exactly where it belongs and that it is clean. If the match didn't light the burner or the flames is not all blue like the rest, there is something else wrong and you need to get back to us with a make and model to better help you. Make sure the burner gets seated back on the orifice correctly and best of Luck to you!
SOURCE: Electric ignition for one burner on counter top ge
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
show diagram main module ge profile counter cook top
The right front burner is the only one, and it stays on high, but seems even higher.
The right front burner stays on high even though I put it on low. What do you think the problem is, the switch?
My right front large burner stays on high all the time
