In the setup menu goto Clock/System goto the bottom till you see factory reset then select that. The DVD player will restart in the initial setup mode.
Those GoVideos are tricky to get the Parental lock pass off... If thats what your trying to do.
Unplug the unit hold the power button on and plug the unit in while still holding power button for 10 seconds.Those GoVideos are tricky to get the Parental lock pass off... If thats what your trying to do.
You can't post conmments that contain an email address.
a you tube video shows a quick way. type in: 'Motorola EX431G factory password reset'. Warning, you have to know the existing factory pass for this to work.
Do a factory reset ,do the following in order making sure that you keep the reset button during this procedure and all should be set back to factory and work .
Now you can set you password to what ever you need to.Remember user name is admin and password is password
1)hold reset button 30 seconds
2)remove power cord hold 30 sec
3)replace power cord hold then release 30 seconds.
You should be in default factory mode and it should work
Hello You can do a factory reset. 1 unplug all cables to router. 2 Hold down small reset button behind router,use a pen tip to hold this button in for 30 seconds. 3 Reconnect cables,power cable first. 4 Log into router using default password and username.Which should be......
username=admin password=password or admin Once loged in you can reset your username and password to what you want.
The only way to is to reset the router to factory defaults and reconfigured it.
after a factory reset the default login/pass is
login Admin
pass blank or password
press the reset button the back panel of your router for 5 secs while keeping it powered ON.
The router would set back to factory settings and password wiped off
reset your router.
it is in back side of router u found reset swich.press it for 5 seconds.then your router reset to factory defaults.
then access with following 2 links 1 is right. http://192.168.1.1 http://192.168.0.1
thn enter username :"admin"
password is"admin"
or password is blank.
then go to settitngs and set pasword
