Six
blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis
function immediately. Check C515 & 516 and the jungle IC, IC206. Might be of faulty IC. Visit the site named 'Electro-help' for
more details. Click this link. View it in
"Timeslide" or "Flipcard" option, which can be selected
from the drop down box menu by the [Sidebar] tag, at the top left corner
of the display window. You can also
click the [Home] tab to see the latest updates. It will make search
easy. There are more than 1350 posts to different brand TVs now. Pull up older
posts there.
How many times does it blink in between each pause? This is a self-test diagnostic code that will help us locate the source of the problem. So please count carefully and let me know.
Hello
Your tv has problems in power regulator side, which is in the printed circuit board of the telivision. Sometimes it may due to some socket contact problems. You just contact a technician., while you cannot do it right by yourself.
i have a sony trintron at home from my observation if you set to much of brightness the tv will start blinking.
the other prevention is that you need to take the tv for service so that semiconductor can be changed, zener diodes and electrolitic capacitor before the tv goes completely fault, like that it be comes cheap and first on the tech to change components.
as time goes these components changes conditions so they need changes from time to time
okay
Likely to have two ic's bad....both are the same. Part number MCZ3001D. Located close to each other. Must be unsoldered and new put in. I have fixed several with this problem
