If you want to change the ringtone on your iPhone, the steps as below will help you to perform this task in an easy way.
1. Tap on "Settings" on the home screen of your iPhone. Then choose the option "Sounds & Haptics".
2. Tap on "Ringtone" in the section of Sounds and Vibration Patterns. Multiple ringtones can be found in the list and you also can see the current ringtone which is being used.
3. In this "Ringtone" screen, all ringtones on your iPhone can be seen here, you can select the ringtone you like whatever the default ringtone or the purchased ringtone or the custom ringtone.
4. You will see Alert Tones when sliding down the screen of your iPhone, Alert Tones are usually applicable to alarms or other notification, but they can also be applied to ringtones as well.
5. You can preview the ringtones that you have chosen, as the ringtone will play once you tap on it, then you can determine whether this ringtone suits your need.
6. Once you have selected the ringtone as default for iPhone, the checkmark beside the ringtone must exist and then you can go away from this screen, then tap on "Sounds & Haptics in the previous screen. Finally, your selected ringtone will be saved automatically.
After that, the ringtone you just set will play when you receive a call.
For more detail, check:
How to Add Ringtones to iPhone
