Californiallero , sepa que en electronica 1 numero o 1 letra distinta pueden significar muchos cambios en la forma de trabajo de un repuesto. el vendedor es vendedor y para el lo importante es realizar la venta, aunque gaste mas mi consejo es que compre otra DLP con el numero original que traia la parte mala que esta cambiando. espero resuelva su problema.
SOURCE: Gray spots on screen on a JVC HDILA model HD 56G 787
Spots on the screen/picture can be caused by three things. Dust on the inside of the screen, on the mirror or in the light engine or optical block. The first two can be corrected by you if you can gain access to the interior. If it is the third (light engine. it will require a technician. If this answered your question, please be sure to rate the answer. Thanks!
SOURCE: jvc hd ila model hd 52g886 red light blinking, and wont turn on
Hi, don`t know if you`ll be able to find this but D9405 a surface mount diode on the main power supply board is a known issue for yours and many other models, it has to be re-soldered not replaced, other joints in area may also need to be "touched up", other than that I had one where connector CN310 was not seated correctly, one side of plug was cocked way up, other than those 2 you may have a bad ballast (board that the lamp is connected to), Be sure that the lamp door is securely closed as they have a switch built into them and if the switch is not closed the set WILL NOT start, hope this helps you out, BMW Rider
SOURCE: HDMI no longer working
Hey, it is another service menu screen. you access it the same way, except push the sleep timer button until you see 30 min, then push display and video status. self check is #2. if any of the categories has "NG" followed by a number, that means that the is an error. See what you can find out.
The HD-ila sets accumulate a lot of dust in the light engine. The worst offender is the little fold mirror just under the lens. I take my set apart about every 8 months or so to clean all the dust from the light tunnel and all lenses, mirrors, diffusers etc. The picture really regains it's pop when this is done. Unless you are a skilled technician though, I would recommend against attemptimg this procedure as you need to disconnect the individual color lcds. Check with a local service center to get it properly cleaned.
SOURCE: HD-56G787 JVC HD-ILA Help me clean the mirror!
pop the front strip under frnt of screen off. remove screws around back edge off screen and under the frnt of th screen. Usa a micro fiber cloth to clen screen.
