SOURCE: dell studio 1737 mousepad not working
You can try the steps below and this definately should fix the issue.
Download and install the latest touchpad driver:
Uninstall the touchpad driver:
1. Click the Start button, point to Settings, and then click Control Panel.
2. When the Control Panel window appears, double-click the Add or Remove Programs icon.
3. Locate the software for your keyboard or mouse in the list below.
• Microsoft IntelliPoint software
• Logitech software
• DellTouch software
• Synaptics software
• Alps software
• Set Point software
4. Click to highlight the device name and then click the Remove button.
5. Follow the prompts to uninstall the input device driver/software.
Download and Install the Latest Touchpad Driver Available:
Please follow the link below to install the latest touchpad driver.
http://tinyurl.com/5k9tth
1. Locate “Input device drivers” and click on (+) sign next to it.
2. Select “Touchpad”, click Download Now. You may receive a warning and an option to run or save the file.
3. Click Save.
4. When the Save As window appears, designate a folder (desktop) to save the file that is being downloaded, and then click Save.
5. When the download is complete, go to desktop and locate the same file.
6. Right click on it and run as administrator.
7. Click on allow and follow the simple instructions to update the touchpad driver.
Please do not forget to rate the solution.
Regards,
Musheer.
SOURCE: CD will not eject from Studio 1737
Open "My computer" windows and select the CD drive . "Right click" on the CD drive.You will get a pop up windows with the "Eject" option.
SOURCE: dell studio 1737 mic driver missing
go to start then go to your control panel then go to classic view if you have vista, go to sounds, look for your mic and enable it.
SOURCE: after turning the computer on, it asks to select
ok, your Hard drive has dropped the boot manager the easy way to solve this is to re-install your operating system ( windows xp vista windows 7 )
this is also a sign of the cpu on its way out also the same for the hard drive if your computer has been getting really hot the cpu may need re-seating.
sorry is not good news
Dave
SOURCE: dell 1737 win 7 do not shutdown
I assume the system is an old model and the essential drivers you have'nt got from Dell website to upgrade it to W7 64Bit. 'Dig' on internet ( too much time wasting but you have a lot). A modified BIOS for W7 may be available. But remember, playing with BIOS is somewhat risky.
Note':If there is a will, there is a way' If you don't mind the cost of an old Dell 1737.
Best wishes.
