Hi Carol,
There are two things that I can think of which will prevent you from sighting through the view finder.
1. When your camera is switched on for live-view shooting mode or vice versa. That is, you can only see the subject in the LCD screen or through the view finder one at a time.
2. If you are using the LCD screen to frame your subject and you encounter this problem, it is most likely caused by the settings of the camera. Try increasing the ISO to around 400 or above, reduce the shutter speed to anything below 1/20 and the aperture to around F:5.6 or less (that depends on your lens.
Hope you resolve the problem by now but if you haven't try those tips.
Regards.
On my Canon Ixus, there is a button on the back by the LCD panel marked "DISP.". This turns the LCD on and off. The reason for this function is to save battery power.
To activate live view you have to set live view to on just as you did and then press the set button and vouala!! image appeares on your screen and if you have selected quick focus you have to press the AE lock button to focus on the subject.
I hope you found this hint usefull.
I believe that the "LIVE VIEW" shooting can only be done in Auto mode. Once in Auto mode, try pressing the SET button located to the right of the LCD screen. Once depressed, you should hear a quick click noise and see what the lens is seeing on the LCD screen. Click on it again and it should revert back to "viewfinder" mode.
Doo, the xs has live view. Hit the menu button, go to the 5 colum, enter Live view function settings. And enable it. That easy!! to use auto focus you hold down the "zoom out." button
p.s. You can always read the manual. :)
Have a good one.
The feature you are referring to is called "Live View mode".
This is NOT available on the Nikon D80, and was only introduced on the D90, which is available now.
Live View mode allows you to use the LCD screen as your view finder instead of using the eyepiece, but unfortunately, this feature is not available in your model.
"Live View", where you can see and compose your picture on the LCD, was not available on any digital SLR before 2007 (the Rebel XTi came out in late 2006). So you need to compose your picture using the optical viewfinder, take your picture, and the picture shows up on the LCD after you've taken it.
But it's still faster than having to wait until the film is developed. :-)
No, the so called 'live view' ( seeing pictures in real time on your LCD monitor ) is available only on the latest models that are coming out now ( Canon D40 and Nikon D3 and D300 have this feature ).
