SOURCE: need an instruction booklet for Wild Country Blaxland 64283 Tent
If you go to www.coleman.com Use the product services link for product manuals. You can then choose tents. Or you can use this link:
http://www.coleman.com/coleman/images/pdf/2000000136.PDF
SOURCE: erect a tent
start with the two longest poles and feed them through (every pole is colour coded so you can't go wrong), that will give you the main shape. peg each corner, once done start with back door section and feed the shorter ones through the loops when done peg it down. then do the same with the other two sleeping sections. finally the front door section (the black/grey coded pole) the pole has a curve which positions in the middle,get that pegged down and put the guide ropes in and it tight. then you can fine tune the rest of the tent sections, once you have everything how you want it, then put guide ropes in. it takes 15/20mins with two people to get everything up, after that it takes 15/20mins for one person to fine tune. hope this helps, if this is your first time putting up the hartford xl it'll take you about 1hr 15mins cause it did me. but it gets quicker with practice.
SOURCE: how do i set up a wenzel monarch tent
If you have the model number (which is sown on a label inside the door flap) you can e-mail Wentzel as I have done and they will send you the set-up instructions. Or email me at [email protected] and I will send you the attachment I recieved.
SOURCE: Wenzel Monarch Tent instructions
Wenzel does. They e-mailed me one for a different model that I bought on eBay. They're website doesn't offer any help but they were very helpful when I called!
1-800-325-8368
SOURCE: I have a Coleman Savannah 6 tent but no
1. Usually you can go to the website of the manufacturer and get a sheet of instructions, or you can get them from a dealer.
2.
Try it. You might find that it is obvious once you get it spread out.
I bought one with no instructions once, and there was only one step
that took a while to figure out.
3. Try a friend or neighbour who is an experienced camper. They might be able to figure it out pretty quickly.
