Flames should never be high and yellow on your mystery appliance.
All questions need full 'make model (what it is)', first 3 words.
Call a certified gas technician unless it is a BBQ Grill, in which case clean the spider nests out of the venturi and burner tubes. Yes, not enough air and too much gas.
blue flame? if flame is not blue, then air gap needs adjusting. if blue flame and burner control is on high, then could be your regulator. (assuming tank if full)
flame running back is an indication of insufficient gas pressure or flow. check and adjust the regulator and ensure that there is no blockage in the jets.
First, check that all the gas lines and flame bars are clear of any 'things' or bugs. I had a similar problem with a Webber grill and found out my problem was with the gas bottle. The new Overflow Protection Valve required on LP bottles can closed off or severly slow the flow of gas when the bottle is full and the valve is opened quickly. It will let enough gas flow to light the grill but won't let the fire get high enough to heat the grill up. Turn all the valves off on the grill and gas bottle. Open the gas bottle valve slowly then turn on the grill burner and try lighting it. If the flame is still very low try again or you have to let it burn at the low level until the OPV float drops down and the valve doesn't impede the gas flow. The best way to avoid this in the future is to not fill the gas bottle to the top when you have it refilled. Just ask the LP attendent to not fill it all the way.
yes the control knobs are what controls the heat, its a saftey thing on the bbq so turn off tank undo gas from tank open knobs release gas from line , turn off control knobs , reconnect gas line to tank ,turn on slowly , turn control knobs to on and light,
Hello. The conversion of any gas appliance usually requires changing orifices, regulator and burner. Then once those changes are made you can adjust the gas flow. The difference in the orifices is this.
Natural gas orifices are larger than liquid propane orifices simply because the gas pressure for the natural gas is lower.
I would double check to be sure that you have installed the correct orifice. Also, you can adjust the amount of gas by turning the orifice in or out, using that socket.
Please call the uniflame technician directly if you still have a problem 800-762-1142 Joe
The rotisserie should have a thermocouple near the burner. If you have to hold in the knob, or push a red button to get the gas to flow to the burner, and the electrode sparks and the burner lights, you have to continue to hold the knob or button in until the thermocouple gets hot enough to keep the gas on. If the burner keeps going out, you could have a bad thermocouple.
