Invacare Pronto M51 Power Wheelchair Logo
Posted on Aug 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My invacare pronto m51 wheelchair does not turn on. we just had the battery replaced. when it is plugged in the battery lights turn on and when you unplug it they do not even turn on.
Anonymous
Level 3:
  • Master 692 Answers
  • Posted on Aug 17, 2010
Anonymous
Master
Level 3:
Answers
692
Questions
0
Helped
288843
Points
1801
Did you replace both batteries? How old is the chair? Sometimes the on-off keypad becomes worn and does not make contact with the on-off switch. When charging the joystick lights can light up but after unplugging they should remain on. When you plug in the charger look under the rear cover at the charger you should see 2 lights, one red and one yellow to indicate that you are charging the chair if you do not see both lights lit then the charger is bad or has a blown fuse. Only a Tech will be able to tell what is wrong. If Medicare purchased your chair then they will pay for most of repair costs. Contact your provider or a repair service company
How do I troubleshoot m51 pronto scooter. When I plug it in there is no lite and of course it does not run
  1. Pronto M51 Troubleshooting‎
    Adfixya.com/Pronto+M51+Troubleshooting‎1000's Solutions
  2. Troubleshooting Tips
  3. Free Diagrams
  4. Free User Guides
Service Indicator Light Diagnostics - Invacare Pronto M51 ...
www.manualslib.com > ... > Pronto M51 > Maintenance manual
Invacare Pronto M51 Base Manual Online: Service Indicator Light Diagnostics. ... Invacare power wheelchair owner's operator and maintenance manual.
How many batteries does a pronto electric wheelchair use
The Pronto M51 takes two batteries. It takes what is called a U1 size battery.
Pronto M51 Wheelchair doesn't have as much power as it used to. Batteries are good.
Have you had the batteries load tested? How do you know the batteries are good?
M51 charger has solid red light and a blinking green light
Battery is shorted or may have cristlized replace battery. This will solve your problems.
Manual for Pronto M51 wheelchair
Hi. We can supply, but try your local Invacare dealer. If you have luck, send us an email,
[email protected]
PRONTO M51 FEELS LIKE I AM DRIVING OVER ROUGH ROAD AFTER REPLACING THE BATTERIES. WHY?
If you chair was down for a long time before getting new batteries the tires could have developed flat spots on them. Also could have brush problems in the motors that make the motors run jerky from sitting too long.
9helpful
3answers
How do I charge My Pronto M51 motorized wheelchair?
Margie,   Yes you may charge it overnight. If you use it everyday,charge it every night. Once the charger senses 24 volts it stops sending a charge,so they cannot be overcharged.  I suggest when you go to bed put on the charger and unplug it when you get up in the morning.
Top Invacare Health & Beauty Experts
ZJ Limited
ZJ Limited
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
