RIM BlackBerry  Pearl  8100 Logo
Posted on May 01, 2008
WHITE SCREEN Just bought 8100. Charged for 5 hours. Can only get bright white screen when turning on to setup. No graphics. SIM card works as I can make and receive calls. Help?
  • Anonymous May 08, 2008
    can only see a white screen.
Anonymous
Level 1:
  • Contributor 44 Answers
  • Posted on May 03, 2008
Anonymous
Contributor
Level 1:
Answers
44
Questions
0
Helped
13951
Points
56
Using blackberry desktop manager, backup information on 8100 and restore software.
Black and White Horizontal Lines
Sounds like the graphics card just died. You will need that repaired.
1helpful
2answers
HP Pavilion DC6, Radeon Graphics card. How do I adjust contrast?
Start / Control Panel / Display / Settings / Advanced / Graphics Media Accelerator / Graphics Properties / Schemes
lots of clicks! This should get you what you want. You'll probably have to experiment with settings a little to get what is truly comfortable to you.
If this is helpful, please take a sec to rate me. Thanks!
Don
Blackberry storm battery won't charge and device won't turn on.
Hi! My phone had exactly the same problem a few days ago! I got a new battery - it worked fine for a couple of days and here we go again... It is dead! Please let me know what you did with your phone! I have a new BB curve! Thank you!
Have a dark screen but apparently BB is working as I get vibration (but no ring) when either a call or text is coming in. Tried battery reseating and sim card reseating. Checked battery and have good 3.7v...
i bought new phone today it balckberry 8120 pearl and i cant turn it on i recharge the battery like 5 hour and all i can see is a flesh red light that al
White screen with the hour glass wont go away
try to remove your sim card and the memory card out of your unit and try to open it again
If that work then have it run for 5 minutes then turn off again put your sim card not your memory card, then turn it On again
inform us what happen
2helpful
Screen has gone white of my bb 9000
First try reset - take out battery and sim, keep out for a minute, then put them in and restart the phone. Any different?
The next possibility may be re-loading the device software from the Desktop Manager. Any better?
Please post feedback here if neither of these work.
Screen turned white
Remove the back cover, Remove the battery, if the phone is GSM take the little card out of the back of phone by sliding the metal cover in proper direction. Should be arrows. Put the Sim card back in battery back in then turn phone on. If this doesn't work let me know. Main thing is reseating the sim card. (this assuming you a service provider that requires a sim card. )
Camera shows white screen when used outdoors
You are having the following problems:
White balance setting incorrect.
images are too bright
ㆍExposure is excessive
→ Reset exposure compensation
● Adjusting LCD Brightness
1. In any mode with the exception of Voice Recording mode,
press the MENU button.
2. Press the LEFT/ RIGHT button and select the [Setup]
menu tab.
3. Select the [LCD] menu by pressing the UP/ DOWN button
and press the RIGHT button.
4. Select a desired sub menu by pressing the UP/ DOWN
button and press the OK button.
[LCD] sub menu : Dark, Normal, Bright
5. Press the menu button twice and the menu will disappear.
Turn camera off. Try removing the fully charged batteries for 30 seconds, reinsert batteries and turn camera on. Hope this helps.
Blackberry pearl wont go past the white screen with the hour glas
the only thing that you can do with this issue is try wiping the software clean and reinstalling fresh software. You would need the blackberry desktop manager first installed on your home computer. If you dont have the cd the program is more then likely available on your mobile providers website. Once the program is downloaded and installed follow these directions
To perform this procedure, follow the steps below:
  1. Remove the battery from the BlackBerry device.
  2. Double-click Application Loader in BlackBerry Desktop Manager while the BlackBerry device is not connected to the computer.
  3. Click Next on the Welcome to the Application Loader Wizard screen.
  4. When the Communication Port Selection screen appears, connect the BlackBerry device.
  5. When the USB-PIN option appears, click Next. The Device Application Selection screen should appear.
  6. Re-insert the battery and allow the process to complete.
2answers
Blackberry 8100, white screen
The same happened to me when I dropped my phone in my briefcase. It actually still had audio, as it rang when calls came in. However, the rest of the phone was useless. You will need to replace the entire unit, unfortunately.
Top RIM Computers & Internet Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Alexander
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
