The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
SOURCE: Canon SD 1000 time and date stamp on downloaded photo
You can download the manual from the link below: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=323&modelid=14901 From page 37 of the manual it looks like you can only select the time stamp in "postcard" mode. Also the date & time need to be set in the camera first. Please update the question & let us know if the information given was useful to you - Good Luck!
SOURCE: Putting the date/time stamp on my pictures
I have the same problem, if someone solved this, please let me know [email protected]
SOURCE: I AM TRYING TO SET THE DATE & TIME TO APPEAR ON MY PHOTOS.
you can only do date and time stamp under function button go to bottom where you can change size of pictures -go to right to W or wide-this is only setting you can do date time stamp on-when you change pic size and go back to menu you will see it highlighted and you can now turn it on-equals about a 2-3 megapixel size picture only-also just leave settings alone and have printer add it-date and time our always in pic data and most printers can add it
SOURCE: HELP! Getting the date/time stamp off your Vivitar 5100...
When you turn on your camera, press the menu button. That will bring up the screen that has the orange buttons at the top (Capture) (Setup) arrow down using the buttons on the far right side. The down button will be the dame button that you use to delete pictures with. When you get to the botton of the page continue arrowing down and that will bring up another page. Arrow down until you get to the botton there are only 3 items on this page and the bottom item will say the following:
Date imprint ON
Press your enter button (ok button) and up will pop ON or OFF.
Arrown down to the OFF and press enter and that will remove the date imprint from your pictures.
Hope this helps you.
SOURCE: Setting date and time on the picture
OK, I FOUND SOME INFO ON A WEBSITE THAT I'M GOING TO HOTLINK FOR YOU. SEEMS LIKE THE ONLY WAY YOU CAN DATE/TIME STAMP A PHOTO IS TO HAVE THE CAMERA IN THE POSTCARD MODE. YOU CAN READ ABOUT THIS IN THE WEBSITE I'VE LINKED FOR YOU. HOPE THIS SOLVES YOUR QUESTION, AND IF YOU NEED MORE HELP, REPLY TO:ARCLIGHT1217. IF THIS HELPS, PLEASE REMEMBER TO RATE THIS SOLUTION. THANKS!
http://www.imaging-resource.com/PRODS/SD750/SD750A3.HTM
GOOD LUCK!
