I had the same problem with fridge/freezer and repair man told me NOT to use anything that has been in freezer as what is happening is that it is constantly freezing and defrosting because there is not enough gas in the system to cool the appliance. It is possible to re-gas the appliance but service engineer advised me to claim a new fridge/freezer from company which I did. Please do NOT eat anything from freezer as could make you ill.
first look for an air vent in the bottom of the fridge(a small grill on the inside wall) & make sure nothing is blocking it, like bread eg: if there isn't then unplug your fridge & let it defrost, check the drain outlet in the back of the freezer, sometimes a small item like a frozen pea gets into the drain & the water freezes around it causing the air not to return to the freezer from the fridge, to push air into the fridge you must be able to get air out or it presurises,
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for cold control and air deflector As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control. Hope this helpout.....
more than likely the defroster inside the freezer has gone bad. This defroster is located in the space between the fridge and freezer and activates to defrost the freezer and stop build up of ice in the freezer.. If it is bad the freezer will not keep the fridge nor freezer cold.
Dave
It has seperate cooling circuits as you describe the problem can be a leak of refrigerant in the freezer circuit.if there is no heating up in the freezer condensing coil.It has to be check for the leakage.
Check your settings for the temperature controls. Freezer may be set to warm (IE #1) set it mid point. Also set the refrigerator at mid point and go from there to adjust each to maintain the temperature balances.
