Yes the ignitor stays on even after the burner is lit. The ignitor is wired in series with the oven valve. It sounds like the oven valve isn't opening all the way. A new ignitor should solve this problem. The old igniter builds up resistance and doesn't let the correct voltage through to the oven valve for it to open properly.
Tom
The ignitor stays on BUT it dont keep igniting after the burner receives gas..Sounds to me a low gas supply, restriction in the gas line, bad gas regulator to stove or house
SOURCE: Newhome stoves 600 SIDO oven ignites but flame stays low
your problem is the fsd ,iam a x gas service eng.
SOURCE: Stoves 61gdo main oven not lighting
the thermocoupler is at fault it will need replacing if its stuck on pilot the thermocoupler heats up a small capilary tub that swiches the control to the temp regulator
