go to support page on casio. and get your manual. youll probably gonna look for a 3 or 4 digit number located at the back of your watch. once you got the manual. go to page 4. and follow the steps of "Hand Home Position Correction". that should fix it.
i also have ga 110c and i have encountered this issue
The analog clock hands on the Casio 2747 will only turn in a clockwise direction, but there is a way to speed them up when you have to move them far around the watch face.
1. In Timekeeping mode (i.e. Date is shown in the digital display), push button "C" (bottom-left) 6 times to enter Hand-Setting mode. 2. Hold down button "A" (top-left) until the digital time starts to flash. 3. Press button "D" (bottom-right) to advance the analog time by 20 seconds, and hold down button "D" for High-Speed. 4. Alternately, for High-Speed, press button "D" (bottom-right) and button "B" (top-right) together at the same time, and then let go. The hands will continue to move automatically. Press any button to stop them BEFORE they arrive at the desired time, then press button "D" several times to arrive at the time of your choosing. 5. Press button "A" (top-left) to exit. 6. Press button "C" (bottom-left) if you want to return to Timekeeping mode.
The hands are set independent from the digital display
Setting CASIO G-Shock Watch
1) Home City 2) Setting the digital time 3) Adjusting hands 4) Alarm set/on/off 5) Snooze 6) Hourly Chime
A -- B ( ) Button reference C __ D
1) Select home city first (if equiped): Press C until regular timekeeping mode is reached. Hold A until seconds flash. Press C to get to city code. Use B and D to move city east or west to your home city. Press A to set and exit. Press C until timekeeping mode is reached (high beep).
2) Set time, Date, etc: Hold A until seconds flash. Press C until item to adjust is flashing. Press B or D to adjust. Press C to go to next item. Press B or D to adjust. Press A to exit.
3) Adjust hands (if equiped): Press C until H-Set is reached. Hold A until time flashes. Press D to advance minute hand. Press B while holding D to set faster and continuously. Press D to stop hands before correct analog time is reached. Press D to step to current time (hands only go forward). Press A to exit H-Set mode. Press C to return to timekeeping mode.
In Timekeeping mode B is illumination and D is time/day/date display advance.
4) Alarm set/on/off Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select alarm to adjust. Hold A until alarm time flashes. Press B or D to adjust alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn alarm on and off. Repeat for AL2 - AL4. Press C to return to Timekeeping mode.
To stop any alarm, press any button.
5) Snooze (SNZ): Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select snooze alarm (SNZ). Hold A until snooze alarm time flashes. Press B or D to adjust snooze alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn snooze alarm on and off. Press C to return to Timekeeping mode.
To cancel the next snooze: Press C until the timekeeping screen is reached or go to the Snooze alarm (SNZ) screen.
6) Hourly Chime (SIG): Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select hourly chime (SIG). Press A to toggle chime on and off.
See: http://ftp.casio.co.jp/pub/world_manual/wat/en/qw4303.pdf and go to the section "Adjusting the Home Position"
This is a "calibration" procedure to get the motor of the analog movement back to the home position of 12:00. This worked for me, after replacing the battery.
Note that in this procedure the hour hand does not move separately, but moves with the minute hand. So to get the hour hand to move, you have to let the minute hand spin a number of times until you get the hour hand up to twelve o'clock.
Dear I received gift of G-300 Casio watch but could not adjust the analog time where as digital time adjusted. Could you please help me to guide for adjsuting its Analog time.
Looking at your watch face: the upper left button is A, upper right is B, lower left is C and lower right is D.
Get your watch into "Hand Setting mode" That is the mode witht he digital time and seconds above it.
From Day and Date window it would mean pushing button "C" six times to get to that mode.
Once in "Hand Setting Mode"
Hold down button "A" til time blinks, then press button "D" to advance the hands, to the desired time.
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
