Re: On my Ultra Jet 3 th power lights keep flashing?
Count the number of flashes IE 3 flashes a pause then 3 flashes this is a error code and tells the tech what the problem is. Without knowing the number of flashes I cannot help. If you have your owners manual there should be a page for error codes somewhere near the joystick page
You have a dead short somewhere. You need some electrical knowledge and a digital multimeter for testing. Take all the covers off. Look for wiring that has rubbed through and touching or melted. Disconnect one of the motors and replace the fuse. If it still blows, reconnect that one and disconnect the other motor. If one motor doesn't blow and the other does, you know you have a faulty motor. If neither stop the issue, then you move up to the controller and look up there. With a meter you can check for shorts within the motors, as well as grounds.
Or just take it to a Service Centre and have it repaired and serviced properly.
https://www.pridemobility.com > pdf > us_jazzy
PDF
Jet 3 Ultra www.pridemobility.com. 3 ... If the circuit trips, allow your power chair to "rest" for approximately one minute. ... thermal fuse on each lead.
INFINFB2045 Jet 3 Ultra Troubleshooting
https://www.pridemobility.com/.../troubleshooting/infinfb2045_jet_3_ultra_ troubleshooting.pdf
File Format: PDF/Adobe Acrobat troubleshooting instructions for the Jet 3 Ultra Power Chair. ... What if the systems on my Jet 3 Ultra seem to be "dead" (controller does not light up when the on/off key is ... you continually allow the battery condition meter LEDs to fall into the red area, the ... 1 Flash. The batteries need charging. Check the battery connections.
Hi u cant rely on battery voltage it won'tell u the condition of the batteries....
The BATTERY'S HAVE TO B LOAD TESTED
ONE AT A TIME WITH A 12 VOLT LOAD TESTER
AVAILABLE ON E/BAY COST APROX $30
THIS WILL GIVE U A GOOD INDICATION ON THERE CONDITION....cheers
Flashing lights on a controller are showing you a trouble code. To find out what the code means, count the blinking LEDs.
Here's a link to Pride's troubleshooting guide for the Jet 3:
Do all of the speed lights flash at the same time or do they ripple from left to right? If they ripple from left to right the chair is in lock mode and you can use the unlock procedures from my tips to unlock. If they are all flashing at the same time you have an internal joystick problem and the joystick needs to be replaced Hope this helps
