Sharp VC-A560U VHS VCR Logo
Russell Taylor Posted on May 01, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Changing from sp to ep
I have lost my remote and I need to know how to change the play from SP to EP
Anonymous
Level 2:
  • Expert 78 Answers
  • Posted on May 02, 2008
Anonymous
Expert
Level 2:
Answers
78
Questions
0
Helped
27996
Points
110
It will automatically play at the speed the tape was recorded at. but if you want to change record speeds here's how: you should be able to access menu functions from the front of the vcr, if so, put a tape to be recorded into the unit and then set the timer for a couple of minutes.while you are on the timer menu it will ask you for recording speed. set the timer record speed to ep and let it record for two minutes and let it record for the full time untill it stops recording. the record speed will automatically change settings to whatever you used last on timer record.
1 Related Answer
Anonymous
  • Posted on Oct 30, 2008
SOURCE: changing to ep
Hi, Try push (Menu) button on VCR Recorder to see Tape speed. Then follow instructions on TV to change speed of tape........Crazyred94
My plug has been changed how do I get ep off of my unit
Which plug did you change? "EP" stands for Extended Play. A VHS recorder has three speeds. EP is the slowest. A standard 2-hour tape will record for 2 hours at the highest speed (SP), 4 hours at the middle speed (SP) and 6 hours in EP. There is a trade off. The faster the tape moves past the recording/playback heads, the higher the picture quality and visa versa. So EP gives you long recording time at a cost in quality.
I doubt that the unit being in EP mode has anything to do with the cable. You did not say what brand and model recorder you have, but in general, the speed is adjusted with a switch on the front panel (older models) or via your remote control.
Changing sp mode to ep
Are you asking how to change the record speed to extended play? This is usually given as a choice when programming a recording. You use your remote to scroll through various options on the input screen and you should find that you can choose between sp/ep/lp (standard, extended and long play)
SONY keeps switching to EP at beginning of playing SP tapes
You may have dirty heads in the vcr---most 4 head machines use two for sp and the other two for lp and or ep.
Tape residue will usually be seen on the drum where the heads are when this happens--also look for the black residue on the tape guides that hold the tape in position against the drum-------
1helpful
VCR LP/EP compatibility
Vdumitre -
No, not usually. If you've recorded a tape at LP and put it another machine that doesn't have LP, it usually won't play properly. Some machines that have only SP/EP will do this, but they are got scarce as more manufacturers dropped the LP speed. Your best bet is to buy an older one from a thrift shop or a garage sale, making sure that it will play LP. Then, copy your older LP tapes to SP or EP (Run the OUT from the LP unit to the IN on the SP/EP unit, and choose "record from line in", "aux", or "rear input").
Thanks,
videoman7
1helpful
Change VCR settings from SP to LP or EP
Hi;
I have a Panasonic VCR with a different, but I know how to 'fix' your problem on my m/c. The remote for my m/c has a "REC MODE" button; operating that button changes from SP to EP etc. Check it with the "Program" button on your TV screen.
harrisonmx3
What does sp and ep stand for when setting the record timer on the vcr
SP = Single Play (normal 1:1 recording)
EP = Extended Play (normally allows two, four or even eight times the normal or Single Play length to be recorded, according to make/model.) Picture quality in EP will not be as good as SP.
Vcr recording speeds
Yes. SP is "Standard Play" and LP is "Long Play", while EP/SLP are short for Extended Play/Super Long Play respectively.
I don't have a remote, how can I change from SP to EP?
I have an inexpensive universal remote that allows me to make the switch.
Changing to ep
Fisher vhs
Sorry, you need the remote. There are sites that sell remotes.
Try partstore.com
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
