Please check if you have the correct part number bulbs? The front and rear bulbs are dual filiment, one for the signal and the other smaller one is a running light. If the bulb you have are correct, does your 4 way flasher function work and or left turn signal work? If the remaining rear flash ok, then your flasher unit is OK. You can also check the bulb running light by turning on the headlights. You might have a faulty or incorrect bulb if it does not light up.
I just recently had he same problem with mine. I replaced the front right turn signal bulb, but after a week of it working correctly, my wife complained that the turn signal did a double time fast flash. I found the rear bulb signal/ brake bulb was out as well. So I decided to purchase a dual pack bulb set and replace both the rear brake/signal bulbs (bulb number 4135) Your auto part store person can look up the correct number for the bulb brand you choose for the van. Since all the bulbs are about the same age and wear, I would recommend replaceing all of yours. Good luck.
Wipe the ink cartridge connection side with alcohol and a tissue or q-tip and try again. If still having problems rub with an eraser and then the alcohol again. If still have the problem, remove both cartridges, pull the pwr plug and hold down OK and cancel buttons for 10 sec while plugging it back in. Printer will reset to out of the box new. Turn on and install cartriges and do an alignment.
More likely to be caused by an incorrect printer driver or ink cartridge issues. Check if the cartridge is placed correctly. If so, Try to use it at leaks once per week or the ink will dry stopping working.
Hello there: what this is refering to is that the cartridge is either not the right one for the printer or the device is having a problem with that cartridge i would remove the cartridge and verify that it is the right one that goes in their and also since youare having the cartridge out i would clean out the contact area to get rid of the old ink that may be sitting on the contact areas ok best regards Michael
If it's not an original cartridge you can expect problems. I tried remanufactured or OEM type cartridges and lost an Epson and a HP printer to printing problems within a week.
Have you tried carrying out the printhead cleaning and alignment procedures since fitting it ?
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Hi for solution do this
First put out of the printer the Ink Cartriges then
press 4 + # + OK this send you a info menu
with the nav. Keys go to CHECKSUM FOR RELOCK DATA IMPUT press Ok 5 times . Then Go out there by pressing Cancell Button ant there you go if this dosnt work at the 1rs time you need 2 o 3 times more to ensure relock data ok
bye :)
