Question about Panasonic Audio Players & Recorders
Hi I have just purchased a Panasonic Plasma TV and Panasonic home theatre. Everything works well except for I cannot get sound coming out of the home theatre when watching normal TV. I purchased the appropriate cable, so thats not the problem. When I do try to use the Theatre system whilst watching TV the TV sound also dissapears.
    Brigadier General:
  • 8,546 Answers
Try running the audio from each video source (NOT the TV, which is an output, not a source) to the HTR digitally so you'll get the best mutichannel sound possible. Then you can turn the TV speakers (assuming it has them) off for hi-end watching.
Posted on Aug 16, 2010
SOURCE:
Samsung tv to panasonic sa bt100 home theatre
it is the problem with the hdmi cable .. dont buy cheaper cables it may damage after some time
Aug 24, 2012 | Audio Players & Recorders
Lg plasma 50 trying to configure hdmi to play tv sound through panasonic home theater.
You will only be able to use the HDMI if you tv has an output for it(for other things beside built in DVD player of home theatre). It can not be an input. If you want everything that plays through your tv to then play through your home theatre the easiest way is to use white and red composite audio cables(some call them rca cables) More than likely you tv will have this output.They will go from the output of the tv to the input of home theater. If your home theater has a Blu-ray or DVD player you need to use the HDMI from home theatre out to in on the tv. If you tv happens to have and OUTPUT for fiber optic audio or digital coaxle audio on your tv and your home theatre has same but as inputs that will work as well with a better quality sound. However this is very rare.
Dec 13, 2010 | LG 42PB4D 42 in. Plasma HDTV
Ghosting of picture from a Panasonic home cinema system
There must be a fault in the screening of the internal wiring to the scart outlet in the home theatre system. I simply changed the way the player was connected to the TV and the interference disappeared:-
1.) I used the RCA video outlet instead of the scart lead. Picture quality was not compromised. FYI the Panasonic Plasma TV I have has only RGB video input sockets at the back, so I used a scart to RCA adaptor to overcome this problem of connecting old technology to new.
2.) The surround sound when playing DVDs is generated directly from the home theatre system so there was no need to connect the audio from the home theatre system to the TV
3.) I used a pair of RCA leads to connect the "audio out" from the TV to the "audio in"on the home theatre system to provide the option of TV sound through the home theatre system.
Mar 18, 2009 | Panasonic Televison & Video
TV Audio won't come through the Home Theatre Speakers
why it doesn't come. just connect the RCA cable to the output pins of TV and connect them to the input female jacks of home theatre receiver. or if the TV has optical out and the home theatre reciever had optical in. thats the best option. just connect one optical cable to enjoy the 5.1 sound. tell me clear problem if u r nt solved.
kanny_amancha@yahoo.com
kanny-sounds.blogspot.com
Jan 26, 2009 | RCA RT2620 Home Theatre System System
Will my Australian DVD recorder & Plasma TV work in the USA?
Hi. No they won't work. Different systems here (found out the hard way). Ironically we are now moving back to Australia from New Jersey and we have nearly the exact same system that we have to sell before coming back !
Jan 19, 2009 | Televison & Video
No sound from plasma to home theatre
First off it's always best to start from scratch when it comes to home audio. LoL. Many times I've been in this situation.
So with everything disconnected. You should have your HDMI, COMPONENT, RCA(R,W,Y)
HDMI and COMPONENT are the exact same thing and in all preference COMPONENT is far better thand HDMI for the pure fact that each wire is in it's own casing and insualted to avoid feedback from the other wires.
Anyways, with everything disconnected we begin
From you Cable/satellite box- Run your HDMI cable from you cable box to your HDMI 1 input on your tv.(If your speakers were to work on your tv you would automaticaly get sound and picture)
That should be all that you should be running from you cable box. Now that we have one thing running we go to the next thing.
From your TV run your audio out (RCA Red/White) to your amp. Usually your preference but more than likely your TV IN on your amp.
With your amp now set on TV, you should automatically get sound from your tv. and if your running an HD cable box even though your only running RED/WHITE to your amp, you will still be receiving Digital sound.
Most new amps Should have a digital input and if your running and 1080iUp this one RCA plugin will give you dolby digital sound from your dvd player to your amp. Then running a video rca up to your tv, will give you the picture, while the digital out on your dvd player to your amp will give you dolby digital sound.
It's a basic simple step to get sound. Like a continuing current. So just as long as you have your cable to -- tv -- home theatre. Everything should work. Otherwise I would go and check your cables and make sure they are not faulty.
I hope this confusing walkthrough helps.
Jun 23, 2008 | Panasonic TH-42PX60U Television
Panasonic Home Theater won' play sound from TV
plug evey thing back how it was befor u unpluged the components to consolidate wall outputs.
May 11, 2008 | Panasonic Home Theater System System
Hooking Up The Theatre System to the TV and Cable.
this means you likeley have your cable box connected correctly, if you have it connected to a standard definition input (AV in or coaxial) make sure the that the dvd player is not in progressive mode.
Jan 27, 2008 | Panasonic SC-HT680 System
Panasonic home Theatre
You need to obtain audio leads and connect from home theatre directly to audio input in back of tv - be careful as there are normally 2 in back of tv
Dec 14, 2007 | Panasonic SC-HT720 System
244 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Joaquim Martins
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
