Hitachi 43UWX10B 43" Rear Projection Television Logo
Anonymous Posted on May 01, 2008
Hitachi 43uwx10b ok. you say it's a restor. but witch one and where is it in the tv. on witch board is it on.? can you teel me.?
Anonymous
Level 3:
Genius:
  • Master 1,153 Answers
  • Posted on May 11, 2008
Anonymous
Master
Level 3:
Genius:
Answers
1153
Questions
0
Helped
324808
Points
2386
Sounds like you need a schematic
2helpful
Hitachi 43UWX10B - LED Light on constantly on will not go off
Power relay is defective. All contacts are not opening when power is removed. Located on small power supply board, upper rt side.
s 901 part# FJ00142 should be under $10, do a google search with part number and 50 sources will appear.
easyab
s901, FJ00142
Hi I have a teac CTM809SV crt tv and on any av input displays a blue and green color. Will pick up the channel ok but with a purplehaze.have tried turning off for 10 minutes but no luck-any tips...
Ur tv have a convergence problems.It dead.The tv convergence board require 2 STK convergence ICS and some or all it resistors to change to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
2answers
Manual Convergence adjustment on Hitachi 43UWX10B
I would guess you missed a open resistor--there are only about 12 of them--how did you check them?
This set (43uwx10b) has a tiny blue micro switch on the front of the chassis---if you engage it from the front the set will go into the DECAM or convergence mode--let me know the CLU number on your original remote and I will scan and paste instructions---98% of the time if the set is wacked out and will not adjust one of the resistors is gone---ONE OF THE CHIPS GETS THEM.
SD TECH
Hitachi rear projection tv wont power on makes a chirp
You could have a bad HV Transformer causing it to shut down.
43UWX10B Hitachi rear projection HD ready TV
Replace Convergence ICs STKs will have Part # on them big black ics For parts 1-800-223-3205 www.electronix.com you have 2 of them replace Both!
2answers
Hitachi hdtv model 43uwx10b is showing a green shadow on the left side of the pictures
Good Day;
If you order KIT 10 from B&D ENTERPRISES at 1-800-458-6053 The KIT will include all parts neede and layout of part value & locations on simple paper lay out diagram.
Good Luck, big IRISH.
My Hitachi 43UWX10B television
Needs Convergence IC
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
Hitachi 43UWX10b tv ceeps bepping or cherping
Research at www.HitachiServiceUSA.com....................T.
5helpful
2answers
43 inch Hitachi UltraVision model # 43UWX10B
I need help
Take it to a professional, this problem u cannot handle
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
