SOURCE: Health Master 100 - blade came off
Jack Lalanne is out of the blender business. The bearing that surrounds the Knurled piece that you insert in the motor each time you blend are not "sealed" so consequently water gets in there and causes them to fail.
They only thing you can do...is to buy a new caraffe from Cooking Toys ...google it...
It will cost you 45 bucks plus shipping dont buy any extras!
After you receive it BE SURE to oil ( a couple drops will do)the bearing that surrounds the knurled piece that is inserted into the motor each time you blend. Inthis way the unseale dbearing will remain lubricated and will last you awhile. Mine became frozen and I was able to un freeze it and my bleender works fine now for months! An dI use it 3 times a day! I expect I will have to buy a new caraffe..in the future because of corrosion...that I could have prevented with oil.
Any questions? [email protected]
SOURCE: Product motor failure
Take your motor to a small appliance repairman. It might be something very simple that failed like a loose wire...then follow my tips below..................
I have been thru the fire about this! I sent my Healthmaster in recd
another and it failed also. Almost always..it is the bearing that fails
in the caraffe that supports the blade. The bearings that Jack Lalanne
had installed in China..were not sealed...so they would allow water to
enter corrode and eventually all of your blenders contents would come
out thru the bottom! Or another thing that can happen is your blade
will freeze up due to corrosion....and become immovable.
Jack
Lalanne healthmaster is out of business. I manged to get a refund from
Tristar..lalannes distributor..BECAUSE they authorized me sending my
belnder back for a new one...and then they cashed my shipping check and
then threw out my blender!!!!! I also had to call for weeks till I
drove Tristar insane...so they ponied up the dough
So I doubt you can receive any money.
But this is what you CAN do!
1)
If your motor functions well..you can buy a new carafe for 45 dollars
or so from Cooking toys ( google cooking toys and it should come up)
2)
OR if your cheap like me...and your blade doesnt rotate easily due to
corrosion and your caraffe isnt leaking much...put a couple drops of
oil on the outter rim of the bearing ( That would be located directly
on the bottom of the outside of the caraffe..it surrounds the knurled
metal part that is inserted in the motor for blending.
My blade was
corroded and leaking a tiny bit..I put some olive oil on the bearing
and it worked great! I have been able to use my caraffe for a month
now...when I expected to have to buy a new one from "Cooking Toys"
Which I will do if this one fails.
3) If you buy a new caraffe form
cooking toys..my advice? OIL THE BEARING WITH A LITTLE OIL...(any kind
of vegetable oil) AFTER EACH TIME YOU USE IT! I SUSPECT IT WILL LAST
INDEFINITELY>>>BUT TIME WILL TELL!
SOURCE: I have a Jack Lalanne health master 100 and the
This is a link to the company that is responsible for the Heathmaster 100 http://www.tristarproductsinc.com/about_us/welcome.html
SOURCE: Jack Lalane Health Master 100 Bearing for Blade
We no longer offer the Jack Lalanne Health Master Blender or offer support for it. For Warranty, Service or Parts, Please call the Manufacturer- Tristar at 973-575-5400 ext 129
