SOURCE: How difficult is it to replace the bearings on an
Bearings MAY be bad from a bad seal. To do this right you MAY need an arbor press to insert new seal without damaging it.
SOURCE: Removal of impeller and screw - is it clockwise or
The attached may be able to assit you.
http://www.goulds.com/pdf/7381.pdf
Tom
SOURCE: my a.o.smith sq1202 pump is slowly leaking water
replace the seal in the pump housing, behind the impeller
SOURCE: pump runs for about 15 secs then cuts off.
try testing the starting capacitor by first disconnecting the power, opening the cover on the end of the motor, and test the resistance of the capacitor
