SOURCE: both left and right speakers play audio for right speaker
I think you mean the left channel is out but when you use test tone, the sound comes from left and right channels through the right channel speaker. If this is case, the switching IC is malfuncting. Unit needs service
SOURCE: records on right channel only so only get music from right speake
If you are recording from an outside source check the connections are good. If it does it from both IE dubbing and external it is possibly that a wire has detached from the head of the record head. The other likely source is the record amp inside the deck. Trace the leads from the Tape head (recording one) and see if you can locate a switch, these can get dirt on the contacts and cut out channels (clean with Servisol video 40). It could also be the electronics especially the amp chip!
If not then the head itself may have gone.
SOURCE: Sony, Compact AV System DAV-SC5 DVD says ready, but Can't play
My player was working fine till today. When any DVD is inserted it say "PROTECTED" and won't proceed further ! what could be the problem?
SOURCE: psp
For playing music,you need to download music in the mp3 format other formats do not work with the PSP,you can download it from beemp3.com .Once you download your music save it in your PC and connect your PSP and drag or copy and paste the songs into PSP memory stick in the music file.
SOURCE: When I play CD only the right speaker is play but
first- is the tuner set to mono or stereo? if stereo, stop using the analog rca jacks and use an optical (toslink) cable to transfer your audio to your receiver. almost all cd players have this output and the same with the receiver. better still, if you are using a late model cd or bluray, and your receiver has hdmi inputs use those as they will transfer both audio and video with one cable.
