Exercise & Fitness Logo
Posted on Aug 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need assembly instructions for nordictrack act
Anonymous
Level 2:
  • Expert 103 Answers
  • Posted on Aug 16, 2010
Anonymous
Expert
Level 2:
Answers
103
Questions
0
Helped
99050
Points
350
Hi there. You can go here and enter the model number In the model number box and download a manual for free.
http://www.iconservice.com/CustomerService/manuals.do
The model number for that unit is located under the ramp assembly or the bottom of the unit.
Good Luk, Tim
Nordictrack e7.7 incline wont lower.
Based on the symptoms you described, it's possible that your Nordictrack e7.7 elliptical may require a new motor/linear actuator assembly to fix the incline issue. However, before making any replacement, it's recommended to have a professional technician inspect and diagnose the issue to confirm the root cause and ensure the correct replacement.
2answers
Were is the port to plug in the ac adapter for nordictrack SL 710 ?
There is not a port, refer to instructions. You can google your model and there a free instructions on line, try it.
Here is big hint if you cant or wont google your model. It to less than 1 second to find instructions
https://www.manualslib.com/manual/506973/Nordictrack-Sl-710.html?page=8#manual
NordicTrack C900 Pro Won't turn on
Double check:
Chances are that "$%#T Happens" is not your problem. And that if it worked prior to "dis-assembly, it should work after re-assembly". The common denominator is you took it apart & put it back together. So.. something was missed. A wire not connected, a switch not flipped, a wire in the wrong spot, the safety key not in the slot, etc, etc.
Good Luck
My 390 E is locked up and I can't move the pedals. I checked the belt, it's still on and it's tight.
follow this steps and fix it. God bless you
Electronics Problem You control the tension of the pedals using the buttons on the console. When you assemble the A.C.T. elliptical, you have to thread a group of wires from the console through the upright down to the electronics board. These wires communicate the resistance settings to the electronics board. If the wires twist, disconnect or break, the resistance will not work. You will need to reconnect or replace the wires.
Read more: http://www.livestrong.com/article/406522-tension-problems-with-the-nordictrack-a-c-t-elliptical/#ixzz2Z4kLeLBm
My A.C.T. elliptical
1) adjust the reed switch, clean, and tight the wire connector well.
2) Run the software calibration for diagnose, troubleshooting and fix it.
God bless you
see the block d
3helpful
Need to disassemble NordicTrack X7i trainer to move it. Don't have the manual
To get the manual go to iconservice.com and select the manuals link. You will be asked the model name or number. You can download a PDF file of the manual for free. Use the assembly instructions only backwards and you will be able to disassemble the machine.
Top Nordic Track Exercise & Fitness Experts
ZJ Limited
ZJ Limited
vince
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
