Epson STYLUS R230 InkJet Photo Printer Logo
Anonymous Posted on Aug 15, 2010
TWO RED LIGHT BLINKING EPSON R230X PRINTER - Epson STYLUS R230 InkJet Photo Printer
Anonymous
Level 2:
New Friend:
  • Expert 154 Answers
  • Posted on Aug 15, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
154
Questions
0
Helped
44356
Points
499
  • You need to reset the printer
  • Download (http://www.mediafire.com/?9njmgwlxqgj) and extract downloaded software and run it.
  • Click accept button.
  • Set model name, port selection and destination setting and equal to your printer.
  • Click Maintenance Tab.
  • Check mark waste ink pad counter.
  • And the clear the protection counter (reset counter to zero)
  • Then click Ok, Ok
  • done
3 Related Answers
Anonymous
  • 304 Answers
  • Posted on May 02, 2010
SOURCE: printer epson R230X both light blinking catridge not running
reinstall your printer driver.
Anonymous
  • 844 Answers
  • Posted on Feb 25, 2011
SOURCE: TWO RED LIGHT BLINKING EPSON
Welcome to FixYa!
There are 2 causes for this. CD/DVD Guide Error and Carriage Error.
Click the Epson Reference Manual link below to view the steps that you need to do to fix this.
Reference Manual Link http://support2.epson.net/manuals/english/ij/stylusphotor230/ref_g/TRBLE_1.HTM
Note: You can also try to uninstall and reinstall your printer drivers.
Rates and comments are appreciated.
Thank you for using FixYa.
Jas
Anonymous
  • 120 Answers
  • Posted on Feb 10, 2011
SOURCE: My Printer Shown Parts inside
Jast go to the web: tricks-collections.com/epson-r200-r21
and download service tool for epson r 230
then run it in your pc and follow these procese
12 Jan 2006
Please follow the steps below to reset the protection counter effectively.
If you have any anti virus software, please deactivate first.
The resetter software (adjprog.exe) requires specific date to run and your anti virus will prevent that.
Make sure you printer is ON and connected to your computer.
Run "Start.bat" file.
This program will set your computer date to 12 Jan 2006.
Click "Accept" button.
Click "Particular adjustment mode" button.
Select on "Waste ink pad counter" and click "OK" button.
Click on "Initialization" button and the program will reset the protection counter.
Click "Finish" button.
Change your computer's date back when it prompted.
Reactivate your anti virus if any.
Thank you
Epson L361 Service Required Solution Red Light Blinking
The Epson printer red light blinking due to various reasons. The Epson printer light blinking when you have paper jammed, low ink tank, Epson printer printhead overloaded, when printer fuser not working and more.
Fix the Epson printer red light blinking error with simple methods:
·Clear Paper jammed in printer
·Check printer Ink cartridge
·Check printer network connection
Follow the more troubleshooting methods to fix the Epson printer red lights blinking issue.
Two red light
my epson r230x, that problem is two read light
2answers
Welcome to FixYa!
Jas
I will use epson r230x photo printer but today a problem is accurad both the light paper out &ink out led are blinking rapidly how can i solve this problem
hello, I have found this that may help you:
"remove any paper in the printer. Press the load/eject button for about 30 seconds. Then press it again. Turn off the printer, wait a few seconds and turn it on and try printing again".
Hope that can help
2helpful
I have epson stylus photo R230X model printer the paper and ink idicators are blinking continuesly the head carriage is moving smoothly but at last moment when it is about to reach at orginal position an...
This printer needs a service, the waste ink tanks are full. The printer needs to be opened up, and these waste ink spounges need to either be replaced or cleaned. Use disposable gloves and water to flush out the ink. Dry out the sponges in the sun, and reinstall them.
Download the Full version resetter epson stylus photo r230x [TRUSTED DOWNLOAD] from this link http://www.general-search.com/download/resetter-epson-stylus-photo-r230x
Once unziped and installed, double click the application and find the reset waste ink counter reset it. This should solve the problem.
You will be printing in no time.
Your timely rating of this soloution is much appreciated
Thanks
94helpful
10answers
Service required for EPSON STYLUS R230
http://www.efillink.com/Support/HowToWasteInkDrainR200.html
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
