Samsung YP-K3JAB MP3 Player Logo
Posted on Apr 30, 2008
Unable to Safely Remove YP-K3J
I've tried about everything...
I've updated the portable device and still I can't safely remove the mp3 using Samsung Media Studio or anything else for that matter.
I opend Samsung Media Studio, plugged in my mp3 and then went to Menu>Portable device and 'Safely Remove Portable Device' isn't highlighted.
  • OneDream
    OneDream May 01, 2008
    Okay, I've read around and people are saying I don't need to safely remove the device. But why does my music sometimes disappear? :S
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Jul 02, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
246
Points
The people that say to ignore the safely remove device - are mistaken.
all i can suggest is go to the manufacture of the computer and make sure all your device drivers are up to date.
and depending on your OS - windows update site or the linux / mac / other repositories to make sure all those are updated as well.
How can I delete songs from my Samsung YP-U3 MP3 Player?
  • 1 Turn on your computer. Connect your Samsung MP2 Player to your PC via the USB cord. Power on your Samsung MP3 Player.
  • 2 Wait for the popup screen and select "Open Folder to View Files." If no screen appears, navigate to my computer and double-click the Samsung player.
  • 3 Select the MP3 files you no longer want on your player by highlighting them with the mouse.
  • 4 Right-click and select "Delete."
  • 5 Close the folder and safely remove the MP3 player by using the "Safely Remove Hardware" feature in the system tray.
  • 5helpful
    I cannot install my samsung YP-K3J MP3 Player onto my PC - HELP!!
    Try to update the driver of the player.
    Go to the START menu.
    Click on RUN. type in devmgmt.msc and hit enter.
    Make sure you have the player plugged in and the installer CD should be on your CD drive.
    Now look for the category PORTABLE DEVICES or OTHER DEVICES.
    the YP-K3 should be listed there with a yellow question mark.
    Right click on it and select update driver. Follow the prompts to update.
    The player should be recognized after that.
    Hope this helps!
    Samsung YP-U3 not recognised. This device cannot start. (Code 10)
    1. Connect the USB cable to your computer.
    2. Press and hold the menu[0].jpg button while plugging the other end of the USB cable into the YP-Z5.
    3. When the display shows USB Connected, release the menu[0].jpg button.
    4. The device is now in USB mode.
    5. When through, you must safely remove the USB device. Note: To safely remove the USB device, right click the USB icon ( usb_icon.jpg ) in the bottom right of your screen, and then click Safely Remove Hardware.
    1. Upon disconnecting the device, it will return to MTP Mode.
    1helpful
    Cant connect to pc
    I have no idea how it happened, but i plugged it into my computer to charge. and then i just saw my mp3 player and the screen froze and it says usb connecting and when i plugged it out it still said usb...
    2answers
    3answers
    Transferring files
    I would recommend to try to use windows media player to transfer files to the device to see if you are getting any error...let me know what happen when you do that,...
    2answers
    Samsung MP3 player
    Well try to format the Mp3 from Windows and the device .Tell me if it didn´t work
    2answers
    Unable to safely remove my portable device
    If this is a USB device, you may remove it at any time.
    2answers
    I am unable to click on the safely remove portable device from the samsung media studio?
    may b ur pc as not fully tock the mp3 so i wud try puttin the cd that came with it again or download tyhe software from the net, if u know how to delete from the mp3 plz let me
    know
    Top Samsung Audio Players & Recorders Experts
    ZJ Limited
    ZJ Limited
    Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
