HP deskjet 2360 won't print states door open but it is closed - just installed replacement cartridges
The sensor which reads the door as open or closed is probably being blocked by something so that it is not registering that you have closed it.
My recommendation would be to open the printer, use a flashlight and try to find if there are any scraps of plastic or anything that might be causing the printer to think it is still open.
If that doesn't work, try closing it gently but firmly, and then use two hands to shift the top back and forth slightly to see if it is slightly mis-aligned.
If neither of those are the culprit, there may be a problem with the door sensor that will need to be examined by a repair person, but that is fairly unlikely.
Hope this is helpful!
