Sony VAIO VGN-NR120E/S Notebook Logo
Posted on Aug 15, 2010
The hardware switch/wlan switch on the front of my laptop does not turn on the wlan. When i turn it on, the green light does not turn on and the wlan does not work. When i try to switch to a wlan network, a dialogue box tells me to turn on the hardware switch, even though it's already switched on.
Anonymous
Level 1:
  • Contributor 41 Answers
  • Posted on Aug 15, 2010
Anonymous
Contributor
Level 1:
Answers
41
Questions
0
Helped
9584
Points
79
Try uninstalling the WLAN from the device manager and then reinstall from the Vaio Recovery Center which can be accessed from Windows Help And Support
Dell NetworkDell Wireless 1350 WLAN MiniPC
The Dell Wireless WLAN Card Utility locates, manages and provides information about wireless networks in your area.
The Dell Wireless WLAN Card Utility allows you to create network profiles, connect to an available network, and diagnose connection problems.
Enable the utility through an icon in the notification area of your desktop, or locate it in the programs list depending on which Dell computer you have.
Turn on the Dell laptop and make sure the wireless switch is in the "On" position.
Right-click the utility icon in the notification area of your desktop.
The icon appears as a set of four green, yellow, red or white bars, depending on the signal strength in your area.
Click "Enable Radio."
Right-click the icon and click "Open Utility" to open the Dell Wireless WLAN Card Utility.
Control Panel
Click "Start" and select "Dell Wireless WLAN Card Utility."
Click the box next to "Enable Radio" and click "Apply."
Click "OK."
http://support.dell.com/support/edocs/network/p70008/en/utility.htm
http://support.dell.com/support/edocs/network/p70008/en/wizard.htm
WLAN light is off
The light indicates that the radio for wireless internet access has been turned off. On my Sony the light is on the right hand side nearest me. It is green in color. The on off switch is on the left hand side next to the headphone and microphone jack. Yours may be different but somewhere is an on off slide switch. So explore the sides and back till it is located
How to switch on wlan ?
You can turn ON the WLAN in two ways. The most common way is by flipping the physical WLAN switch ON. The switch is usually located at the front side of the computer (look below the light indicators at the bottom of the touchpad or at the left / right / side of the computer. On some computers, they're above the keyboard.
If that won't work, you might wanna try a combination of function key (Fn+ wireless key).
For Toshiba laptops it's Fn+F8, and for Lenovo it's Fn+F5, Dell and HP usually uses Fn+F2 but every brand has a different combination so check the F1 up to F12 keys for the wireless symbol.
Cheers,
How do i turn on the WLAN for PSP 3003
On the side opposite of the power switch, you should find another switch. Move this switch up and it should turn on the WLAN. A green LED will light up on the lower left side of the unit.
2answers
Dear sir, i can not see the wireless icon on my laptop
do you have the drivers for your wifi card installed properly. if not then go to manufactures website and download driver software for your wifi unit, are you using xp or vista? find device manager and see interfering hardware.
3helpful
Hello, I have a HP Pavilion laptop but the HP WLAN is always disabled. How can I fix this problem?
All laptops have a user button or switch to turn the wireless access on or off. Look for a red light above the keyboard; touch it and it should turn blue (that will turn the access on again). Alternatively, you could have a switch in the front or along the sides to turn wireless access on or off. Hope this helps.
Internal error psp1001
This would be one of the first PSP's so it's not a surprise if it has failing hardware. When the wlan switch is switched on is the light turning on and green? if not it might only be a faulty switch for the wifi in the psp itself. you can either open it up yourself and fix it or have someone that knows what their doing fix it for you.
My Wlan Wont find my network
have you found the actual adapter icon, and right click, and select "Enable" this may sort you out. You may have two...Actual switch, & KB, Key... Plus "Enable". Try this too. - click "Start"
- click "Control Panel"
- click "Classic View"
- doubleclick "System"
- select "Hardware" tab
- click "Device Manager" button
- click "+" to left of "network adapters"
- doubleclick "Atheros AR5007EG ...."
- click "Advanced" tab
- select "Power Save Mode"
- select "off"
- select "OK"
2helpful
I have a compaq presario c700 that has the WLAN disabled and it wont turn on i need help getting it on to find my routor it was working 2days ago now its not any help i have compaq c795tu laptop and my...
in very laptop there is a switch button that determines if your wlan is on or off. Try finding it and switch it to On. I hope this will help you,, if it doesnt work let me know.
Downgraded from vista to xp now blue tooth and wlan switch/are/nw
It most likely would of been the utils that you need to install that will run in the background with regards to bluetooth or wireless ( wlan ) which when you installed the drivers for xp should of given you the option to do.
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
