HI. This will be a basic logic chip fault. It could possibly be solved by simply preforming a hard reset. You can do this by shutting down the power to the unit for five minutes. This shutdown will force the logic sector of your electronic control board to reset its programming. Once the five minutes are up, reintroduce power to the unit and try to initiate a normal cycle. If the disruptions continue after the hard reset, it will be necessary to replace the electronic control board.
Electronic Control Board Part number will be 99003431
Click Here to view an exploded diagram of the control panel of the
unit.The affected part will be labeled number 7 on the diagram provided.
The control board housing will be labeled number 6.
