Cell Phones Logo
Posted on Aug 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I setup wep301 headset to a simple at&t phone
Anonymous
Level 3:
  • Master 370 Answers
  • Posted on Aug 14, 2010
Anonymous
Master
Level 3:
Answers
370
Questions
0
Helped
84098
Points
1402
Follow the steps to connect your WEP 301 bluetooth headset to phone.
1.When you turn on your Samsung Bluetooth
headset for the first time, it proceeds into pairing
mode immediately.
2. If you have paired the headset with other
Bluetooth devices, make sure that the headset
is off. Press and hold the Multi-Function button
until the blue indicator light stays solid blue after
blinking.
3. Set your Bluetooth phone to discover the headset
by following your phone’s guide. Typically, the
steps involve going to a ‘Setting’, ‘Connection’,
or ‘Bluetooth’ menu on your phone and then
selecting the option to discover Bluetooth devices.
4. Your phone will find the Samsung headset and
ask if you want to pair with it. Confirm this by
pressing the Yes or OK key.
5. Enter a passkey or PIN, 0000 (4 zeros), then
press the Yes or OK key.
6. If pairing was successful, the indicator light will
flash in blue 10 times rapidly before going to
flashing every 3 seconds. If unsuccessful, the
light remains on, and you will need to re-attempt
pairing.
7. When you turn on your headset after pairing
with the phone, the headset is automatically
connected to the phone.
8. When you turn on your phone after pairing with
the headset, the phone is connected to the
headset by pressing the Multi-Function button.
Thank You
I cannot get My samsung wep301 to connect to my ps3
When you are searching for bluetooth device on ps3, press and hold the on/off button...main button until the blue light on the side stays lit and that should do the trick.
13helpful
I cannot connect the bluetooth headset to my iphone
Hello
Turn your bluetooth headset off.
If it is on, press and hold multi-function button(for about 4 seconds) until the LED blinks twice.
Prepare your iphone to be ready to go to search mode.
You can see 1.Search 2. Wait for request. Don't press on Search yet. This needs to be done after the bluetooth headset is in pairing mode.
Turn your bluetooth headset on in pairing mode.
(Press and hold the multi-function button for almost 9 seconds. The LED will be steadily LIT.)
Activate the Search option in your phone. You should see Samsung WEP301 in your phone's screen. Choose that and press OK.
The phone will ask for a passkey. Press 0000. (That's four zeros.) Then press OK.
Give it a few seconds, your phone and bluetooth headset will be paired.
Enjoy the handsfree experience.
I need to connect this blue tooth with my phone but I no longer have the manual Samsung WEP301 Bluetooth Headset manual?
you can get it from here,
pls rate me. thanks i need it
www.samsungusanews.com/files/139/WEP301_SS%20lowres.pdf
Jan 23, 2010 • Cell Phones
2helpful
Iphone 3GS can't discover my samsung wep301?
Having the same problem. Any recommendations?
Hello I have lost owner manuel for my bluetooth wep301 samsung does anyone know what do to
Pairing Headset
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
You can obtain a copy of your user manual by locating the FCCID on the label directly on the device, then then going to the FCC Website - https://fjallfoss.fcc.gov/oetcf/eas/reports/GenericSearch.cfm
Be sure to put the first three characters in the first box and the rest (including hyphens) in the second box.
2answers
My WEP200
i have a problem setting up my sansung WEP301
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mike Cairns
Mike Cairns
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
