There is a seal kit that is successful about 90-95 percent of the time in fixing the leaking issue. If you will call customer service at 800-352-2866 with your name and address, we will be able to send you a kit to resolve your issue.
It sounds like a seal/gasket is defective causing it to leak. Please locate the model and date code on the bottom of the brewer and contact customer service for troubleshooting and replacement options.
How old and have your ran vinegar water mixture to clean teh coffee maker? I woould run 1 part vinegar to one part water to clean coffee makers 2 -3 times a year. Here's a vinegar cleaning link.
there's probably a 'silicon rubber' hose that feeds hot water to the 'grounds basket'- it may be loose, or damaged. is it leaking water, or coffee?? we have a bunn 8-cup, which has a pre-heated water tank that brews a pot in about 3 min. energy waster, but when you need coffee, you need coffee!!! is your filter holder properly centered? is the carafe lid hole clean and un-obstructed? if it's leaking water, and not too costly to replace- you may consider replacing it with a new one! good luck!
