SOURCE: linksys keeps disconnecting
Have you tried different ports on the router? If so have you tried other computers hard wired in? Hard wire in one of your laptops for awhile and see if they lose connection as well. If so then the problem is the router, but if they can stay connected then I would try either updating your network card drivers or getting a new network card perhaps. Let me know if that helps any.
SOURCE: Can't connect to Linksys WRT54G when security is enabled
ccmfaniam:
Please make sure that the type of the security on the router should match on the computer as well. Also make sure the SSID on your router is the same in as your computer.
If this does not work, make another profile onto your computer, or simply click on the wireless icon and it should ask you for the security pass, put in the pass and you should be in.
At the moment I would strongly recommend to make another profile on your laptop, right click on the wireless icon, properties, wireless networks, make sure that the use windows to configure is checked and under prefered networks add the profile of the existing router with same SSID and security you are trying to use.
Let me know!
SOURCE: Linksys WRT150N
I only have 3 suggestions.
1st one is to make sure the ssid is not similar to other routers you are using on your profile. ie.(change it to a unique name)
2nd is to make sure you check the box that says broadcast your ssid.
3rd check to make sure you select the router as an access point and not adhoc or infrastructure option. Finally you can try to change the channels eg. i like channel 3 b/c it doesnt interfere with any phone lines.
good luck
smeags.
SOURCE: Unsecured home network
Here is a nice tutorial about setting security on your wireless network
http://videos.howstuffworks.com/labratstv/822-episode-1-setting-up-wireless-security-video.htm
Also, your router's user guide is available at
http://www.linksys.com/servlet/Satellite?blobcol=urldata&blobheadername1=Content-Type&blobheadername2=Content-Disposition&blobheadervalue1=application%2Fpdf&blobheadervalue2=inline%3B+filename%3DWRT54GX2v2_ug.pdf&blobkey=id&blobtable=MungoBlobs&blobwhere=1193765877580&ssbinary=true&lid=0926304580B03
If you feel like reading more, there is a nice tutorial posted by Microsoft also
http://www.microsoft.com/windowsxp/using/networking/expert/bowman_03july28.mspx
Let me know if you run into any issues and I will be happy to help, good luck :)
SOURCE: Unable to connect ipod touch to home network
Sounds like an I.P. problem. If set to "Dynamic", try "Static" IP. Had a similar problem with my Linksys wireless camera. It worked...than it didn't. Sounds eerily similar.
Mike
Click the link below for proper cable connections in setting up your wireless network.
http://www.microsoft.com/windowsxp/using/networking/setup/wireless.mspx
Then, configure your wireless connection. The following links provides the step by step instructions for each version of Windows:
Windows Vista. http://windows.microsoft.com/en-US/windows-vista/Setting-up-a-wireless-network
Windows 7. http://windows.microsoft.com/en-US/windows7/Setting-up-a-wireless-network
I hope this works for you. Good Luck!
Thanks.
Mongkey
"Understanding explains better..."
