Go to lenovo's or IBM's site and download and reinstall the driver.
Get onlineand got to www.google.com In the google search box type: "LenovoSupport" or "IBM Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the Audio drivers.
In your case it is very difficult to find out which is causing the system not to power, this can be multiple devices on your ssytem.
trying to eliminate one device after another try following the steps below:
>remove the Battery from the system, unhook the adaptor as well then Press and Hold down the power button for 7-10 seconds to drain any power on your motherboard.
>after power draining the system connect the adaptor to your laptop, do not insert the battery yet, Power the system without the battery, if the system turns on leave it turned on for about a minute then shut it down normally.
>insert the battery to the laptop turn the system on if this turns on without any error then your concern is probably ok and fixed.
>but if the system still does not power up having the battery connected to the machine a device on your system can or maybe damaged either the Battery or the Motherboard having an issue with the battery conencted to the machine...
if your system is in warranty call Lenovo and have it sent to teh service center for proper checking and repairs.
is this a Y410 or a G410? one might cause that issue is the memory you have there is not compatible with the laptop second would be regarding the size of the RAM that your compuiter can handle each slot. The best way to solve your issue is to call there tech support line to verify the exact model that you need for laptop. This the no
US/Canada
1-800-426-7378
Australia
1-300-880-917
You can check if this product key that you have just mentioned is located at the back of your laptop. Determine if the Operating System is windows Vista which is stipulated at the back of it. If you have a windows Vista CD, check if it is for Ultimate. Then insert the CD and restart the pc. Then repeatedly press F12 to boot to CD. Select ODD or CD/DVD ROM option.
When installing the operating system, check if it prompts you to ask the product key, then it will activate your windows.
Please do the following changes. If you have the drive with you please reinstall the bluetooth driver or restore from a earlier date . for that go to Start+Accerories+System tools and select Restore point. follow the process it will ask to set to a earlier date . select a date when your bluetooth was last recognized . If not select an earlier month and restore. It will then restart.
