Canon imageRUNNER 2270 Copier Logo
Posted on Aug 14, 2010
Hi i am gokul..i have ir3300 machine now this machine is displayed paper has jammed error..but don,t jammed paper last time the paper was jammed fixing unit side..plz give me a solution.. thanks
srinu
Level 1:
New Friend:
  • Contributor 21 Answers
  • Posted on Jan 14, 2015
 srinu
Contributor
Level 1:
New Friend:
Answers
21
Questions
Helped
8568
Points
43
In the fixing unit sensor liver not playing properly pls check it now
Anonymous
Level 1:
Sniper:
  • Contributor 51 Answers
  • Posted on Sep 22, 2010
Anonymous
Contributor
Level 1:
Sniper:
Answers
51
Questions
0
Helped
42662
Points
93
Small torn paper was left on your fixing unit. You can remove the fixing unit look for that small piece of paper. ;)
  • Mohanraj
    Mohanraj May 18, 2014
    d paper vil jammed in inner part side.... otherwise check d paper quality...
Canon ir3300 showing paper jam in 2nd tray but thre is no paper jam in it
  1. Locate and dust your paper sensor eyes
  2. make sure paper size adjuster for tray 2 is locked at proper position.
  3. Examine pick up roller from tray 2, clean or replace as necessary.
5helpful
2answers
i m using canon ir3300 , showing paper jam at left side , but i checked there is no any paper, although there is showing jam. what to do.
Machine reads document jam,checked machine seems ok,cannot sent fax.
Hi there!
The error message that you are getting means there's a jammed paper inside the machine particularly in the feeder. This may also appear if the panel is not closed securely. Try to open the control panel and look for any pieces of jammed paper or debris. Closed the front cover or the control panel, it should display the regular screen date/time. Once you have the regular screen load the document on the feeder, the display should change and should ask you to enter the fax number.
Hope this helps!
Please rate if it worked, Thanks
HP 3030 error message paper jam - clear papaer path. There is no paper in the machine. I have cleared and cleaned the machine, turned it off, waited 30 secondsand turnedit back on and still get the error...
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Fatal code 0x50
Hi, Hope this helps,I downloaded & manually Translated it from a Russian Website (I speak Fluent Russian)!!
fatal error code 10x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Last fatal error code 20xF1 PF PID excess load error. Possible causes : PF Motor failure, PF drive mechanism overload (paper jam, foreign object, insufficient grease, deformation of the Main Frame), Tooth skip of the PF Timing Belt, Improper tension of the PF Timing Belt, Cable disconnection, Main Board failure (Motor driver failure).
Last fatal error code 30x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Last fatal error code 40x0A CR load position excess load error. Possible causes : CR Motor failure, CR Unit drive mechanism overload (paper jam, foreign object, Change Lever failure), Cable disconnection, Main Board failure (Motor driver failure).
Last fatal error code 50x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Heater Unit & Hard Disk problem ir3300
1) what kind of hdd failure? Did copier report error code like E602-0003, or? When the hdd error occured did the service exchange HDD with new one and upgrade the system. Other thing, but not mostly likeble, check the current in el. insert.
2) Wich kind of problems? Did the copier reported E000, E001, E002, E003,..., is there was smudged copies, paper jams,..., how did you solve the problem? Did the service replace fixing film unit, or complete fixing unit? Do you have enough air flow around the copier, is the copier beneath the air conditioning device, is there any air draft,...?
If you want you can contact me on [email protected], for more help.
1helpful
2answers
Dear sir when i start machine ir3300 i get code
I.e. Teflon problem if u getting the paper jam in fusing unit every time teflon is cutted in fuser unit is getting prints after meachine on and off, problem with the sensor u cleam it that's work fine. for any information plz mail me e-Mail : [email protected], 919290062654
16helpful
4answers
My canon iR3300 is displaying error code E000002-0000. Please help.
My canon iR3300 is displaying error code E000003-0000. Please help
1helpful
5answers
Jammed document
JC
I had the same problem- jam error with no paper in it. I tried all of the suggestions to no avail. So as a last resort before I went and purchased another one I unplugged it, picked it up, turned it upside down and whacked it a few times. To my surprise when I plugged it back up it worked just fine! Haven"t had any problem since. I don"t reccomend this but as a last resort, what the heck!
old marine
old marine
ZJ Limited
ZJ Limited
