My phone wont charge. the battery is good and charger
SOURCE: phone says unable to charge
Try a different battery. If that doesnt work, it may be your charger port. Take an old tooth brush, turn off the phone spray alcahol on the toothbrush, and scrub the port on the phone. If that fails your charger port needs to be replaced. Check with your provider about the warranty. If its not under warranty, check my profile and we can help you for sure.
SOURCE: env2 charger wont fit in the hole and wont charge my phone
The issue is the charger port on the ENV2 breaks fairly easily. The first step is to contact your carrier to see if it is covered under warranty. If it is, great get it replaced.
If not, you have 3 options:
1. you can get the charging port repaired. The cost is about 50 dollars.
2. you can get a new phone. cost ???
3. you can get an external battery charger to charger battery separate from phone. cost about 25 dollars. check out the following link for ones that are available on ebay. LG VX9100 ENV2 External Battery Chargers
when i put my charger into my brand new slvr it says battery charging and then just shuts down.. then it comes back up and says battery charging but then just shuts back down and repeats the process
They symptoms are exactly the same. The phone shuts down when plugging the charger in and then recycles through the process, on and off, over and over. Meanwhile the phone does not function.
