Belkin (F5D7230-4) Router (587009) Logo
Posted on Aug 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Netflix states that my problem with not seeing movies through the wii is the router. The movie downloads then redownloads but never can show the movie. netflix states that all is OK with the wii, my internet service and netflix. Help!
Rakesh Warrier
Level 3:
  • Master 708 Answers
  • Posted on Aug 14, 2010
Rakesh Warrier
Master
Level 3:
Answers
708
Questions
0
Helped
209418
Points
1609
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
Goto : my blog for more information about belkin routers (Page is still under construction )
- Tom Riddle :-)
After setting up vizio streamer. I have singed up[ for netflixs and can which trilers but can not download moives what is the fix.
You cannot download movies to your Vizio streaming device. Do you download the moves you watch on TV ? Of course not. A TV allows you to watch movies, shows, etc.BROADCAST OVER THE AIRWAVES OR CABLE. Similarly, a streaming device allows you to watch movie, shows, etc. STREAMED/TRANSMITTED OVER THE INTERNET. So, if you can watch Netflix trailers on your Vizio, you can watch Netflix movies (but not download them). Select a Netflix movie, press Play on your remote and see what happens.
Cant connect my Wii to the internet for net flix viewing
Netflix has come a long way since 1997.
What began as a disc-based mail-order rental service has become one of the pioneers of digital distribution.
Netflix's digital distribution service offers thousands of movies and televisions shows that users can watch instantly from a variety of devices, such as the iPhone, PC and the Nintendo Wii.
Netflix is not available immediately on your Wii when you first turn it on; you must download the program from Nintendo's Wii Shop before you can begin using it.
Select the "Wii Shop" channel on the Wii's main menu and choose "Start."
Select "Start Shopping" and choose "Wii Channels."
Select "Netflix Instant Streaming for Wii."
Select "Free 0 Wii Points" to begin the download.
Choose the location where you will save Netflix.
You can select either the Wii System Memory or an SD card.
Select "OK" and select "Yes."
Your download will begin, and a Netflix channel will appear on the Wii's main menu.
Select the "Netflix" channel, located on the Wii's main menu, and choose "Start" to launch Netflix. The first-time setup screen will appear.
Select "Yes" to indicate you are a current Netflix subscriber.
If you are not, you cannot use the service until you sign up at the Netflix website.
Enter your Netflix email address and password. Select "Continue."
Select a television show or movie in any category to begin watching it instantly.
http://www.nintendo.com/consumer/systems/wii/en_na/netflix.jsp
https://signup.netflix.com/help
Netflix movies will not show, showing error code:51330
Error Code 51330: This means the security code you entered into the Wii is not the same one your router is set to. Look in your router's settings and try again.
2helpful
Setting up wii for netflix
Netflix Instant is available for streaming on your Wii gaming console by early spring 2010. If you have a Netflix subscription you can watch movies and episodes easily on your TV through your Wii console. This article will detail the important things you will need to make sure that you can watch Netflix from the Wii.
Difficulty:Easy Instructions Things You'll Need
  • Netflix subscription
  • Nintendo Wii gaming console
  • Broadband internet
    • 1 Check you Netflix subscription. The minimum subscription plan to watch Netflix instantly is the unlimited 1 DVD at a time plan or otherwise the $8.99 plan. This plan allows to watch movies instantly with unlimited monthly hours.
    • 2 Check internet bandwidth on your broadband connection. According to Netflix the minimum bandwidth requirement is 1.5Mbps. Netflix recommends for watching movies instantly a 3.0Mbps connection. Check with your internet service provider to confirm that these download speeds.
    • 3 A wired connection to your Wii console. An ethernet connection to your Wii console would be preferable. Unfortunately the Wii console does not have an ethernet port but a USB port. A USB LAN Adapter can be found at most computer supply merchants or online from Wii or Amazon.com. The ethernet connection is an ethernet wire from your home LAN router connected to your USB LAN adapter. The USB LAN adapter is then connected to the USB port on the Wii console. This connection will be how Netflix provides the movie streaming feed to the Wii.
    • 4 Sign up at the Netflix website for the Streaming Disc. Netflix will send a specially programmed disc to setup the Wii for watching the movies. When the disc arrives Netflix will provide instructions on how to install onto the Wii gaming console.
Read more: How to Setup Netflix for Wii ' eHow.com http://www.ehow.com/how_5893624_setup-netflix-wii.html#ixzz1OybxaAO2
if this help you please rate me sir thank you so much...
We are trying to get wii programed to watch Netflix movies
If you get on your netflix account online, they should have an option to send you a disc that uploads netflix on to your wii. I also believe that you can download it onto your wii using the "shopping" option. Either way, you will need internet access to obtain it and the movies.
1helpful
I have lan adapter attached to my SAmsung LED HDTV, and have connected to internet via wireless router. Now, how can I access Netflix movies (I have a new account)
Ur new account been approve?Yes,log into to ur account on the Netflix website,just pick ur choices of instantly watches movies and wait a few mins or more depending on the speed of ur internet broadband connection might take a little longer the movies to download and the movies will play instantly.Or games devices and tvs with internet options.U might require or a must have to down load their software and upload into ur games systems like PS3,WII,XBOX or internet tv capability for the Netflix service to work.The games systems will have an Netflex app. show up on it films media player,could be the same with ur tv internet capability option.
How do u get netflix to download on your wii game system so when you turn on your it wii show netflix instead of using the disk
you cant you have to use the disc everytime you want to watch a movie from Netflix. I have it for the ps3 n tried it wont work without it.
Other computers not able to connect wireless
have you downloaded any new software/games/audio/video in the last two weeks on the main pc w/router (that might be conflicting)..if so I would delete it....do not change wii or other computers connection settings....but on the main computer lets do this
1.go to start
2.all programs
3.accessories
4.system tools
5.system restore
6.we are going restore 1 full month...this means pick restore to earlier date....30 days back.......when it was working all fine.....click okay..once say ok again it will reboot by itself come on and will prompt you one more time click ok
good luck
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
