Ryobi (one +) 18v Drill And Saw Combo Kit Logo
Posted on Aug 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My chuck key on my Ryobi Cordless drill/Saw Combo, is stuck in the fully opened position and will not tighten at all. Was working for a while then just happened. Thanks ahead of time.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 29, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1181
Points
Ryobi drill with key less chuck will not open with a drill bit stuck in it
vince janis
Level 3:
  • Master 718 Answers
  • Posted on Aug 14, 2010
vince janis
Master
Level 3:
Answers
718
Questions
Helped
256463
Points
1742
It's just jammed in fully open position, take a set of channel lock pliers around the chuck and unstick it .
3 Related Answers
fisherman816
fisherman816
  • 68 Answers
  • Posted on Nov 07, 2009
SOURCE: my ryobi 14.4v cordless drill won't turn on. The
The problem is most likely the switch.http://www.ereplacementparts.com/ryobi-cordless-drill-parts-c-7931_8051.html
Anonymous
  • Posted on Jul 10, 2010
SOURCE: my 18v ryobi cordless drill does not hold a drill
Make sure the screw for the chuck (down inside
the chuck) is tight this happened 2 me. Brought it back
2 h/d The clerk played with it and the chuck screw fell out.
They replaced the whole 4 pack instead of just the drill.
Graham
  • 304 Answers
  • Posted on Jun 23, 2012
SOURCE: ryobi 18v drill keyless chuck stuck
Try holding the bit in a vice and gently tap the chuck off of the bit and see it it releases the pressure on the jaws.
I can't tighten the drill chuck around a bit.
'make model (what it is)' as first three words of every question please.
All the ways to tighten a drill chuck in the link. I have one with a key and my cordless drill has a central position between forward and reverse that locks the chuck.
https://www.google.com/search?q=tighten+the+drill+chuck
Mar 11, 2023 • Drills
Ryobi 18v drill stuck chuck
easy to fix
with the drill not running
grab the bottom part of the spinning part of the drill nearest the drill's motor.
then
grab the spinning shaft bit nearest the drill bit
pull them apart slightly
when the two parts are pushed together thay lock the chuck
I own a ryobi hammer drill that does the same thing
Ryobi 18v drill keyless chuck stuck
Hi i broke the chuck on my 1/2 makita cordless
Put the biggest hex key you have in the chuck and tighten it then hit it clockwise with the spindle lock engaged a couple of times. The screw in the chuck will then undo clockwise and the chuck can be undone after by putting the allen key back in and unscrewing it anti-clockwise maybe with a light tap from a mallet.
Hope this helps
Jon
2answers
My 18v ryobi cordless drill does not hold a drill bit even tho i hold and tighten the chuck with my hand. It will hold for a wile but will eventually fall out. Thanks
Abrupt stops can loosen the ratcheting chucks. Before the invention of those chucks we had the ones that required a key. The proper way to tighten them is to alternate between all three position in order to "seat" the jaws on the bit evenly.That all but guaranteed it would not come loose I assume you have a ratcheting "one handed chuck". ther's only one way to tighten them and you don't get the same grabbing force. The only thing I can suggest is to try to eliminate abrupt stops or try cranking it tighter.
Battery charges but is dead
The battery isn't any good. The charger is just going through it's regular steps. (I know how it is. I just bought two Ryobi 18 volt batteries for my Ryobi cordless drill, reciprocating saw, flashlight,
trim circular saw, combo set. $60 for two batteries)
Getting a small drill bit in straight and tight
I would replace the chuck or purchase a 1/16" quick change drill bit.
Makita 6405 3/8
according to my breakdown its a drill. do you checked if there is a screw inside the chuck. if there is one remove it by turning clockwise.open the chuck fully & insert allen key 5/16 or 3/8 short side to the chuck.tighten the chuck & wak the allen key with a hammer counter clockwise. do it again if required.putting back together the other way.
6helpful
2answers
Chuck change
After removing the screw and inserting the allen wrench shift the drill to the LOW position and turn the clutch to the drill only position. Use an allen wrench about the size of the chuck capacity so that it will not flex when hitting it with a mallet. Sometimes they are stubborn because of the torque but this should work. Put the allen wrench at about a 30deg angle and hit the wrench. I support the chuck on a workbench or a block of wood will do fine. The chuck has standard threads.
Top Ryobi Drills Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
