Kenneth Cole RK5034 REACTION Logo
Posted on Aug 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
CHANGE THE TIME - Kenneth Cole RK5034 REACTION
Anonymous
Level 3:
President:
  • Master 2,501 Answers
  • Posted on Aug 14, 2010
Anonymous
Master
Level 3:
President:
Answers
2501
Questions
Helped
1291712
Points
7081
You can get instructions by going to http://www.genevawatchgroup.com/ and clicking on "Customer Service". Scroll down to your watch type and model and click on it to obtain the manual.
How can I change Alexa on my Amazon Echo show to 24 hour time.
Question edited for clarity and toss in some CAPS.
Military Time is 24 hour Time, 00:00 to 23:99! It sounds like actually want 12 hour time, 12 hours of A.M. and 12 hours of P.M.
You just ask :>D
Say "Change to 24-Hour clock" or use the Alexa app.
  1. Open the Alexa app .
  2. Select Devices .
  3. Go to Echo & Alexa, or to All Devices.
  4. Select your Echo Dot with clock device. This opens device settings.
  5. Under General, select LED Display.
  6. Turn 24-Hour Clock on or off.
Change the Time Format on Your Echo Dot with clock
How to change time.
just set the time an hour in front of or an hour behind the time of the day
so if you want EDT then set it back one hour if the current time is 9am to make it 8am
that would make it EDT itme
May 21, 2015 • Watches
Change time
Advance the time by 23 hours. And reset the day to the correct one. make sure that the date change occurs at midnight your time and not at noon.
4helpful
How to change time on roots watch ry2203
Press and hold "MODE". Press MODE 2 times (after the first time, the alarm time flashes, after the 2nd time, the second flashes). Press ADJ to change seconds. Press ST/STP to switch from seconds to minute. Press ADJ to change minutes. Then press ADJ to change hours. Press MODE when done.
2answers
The watch shows time in digital plus has hands on it like a regular watch the digital shows one time and the hands show another
Hi jessestaton,
All you would have to do is change the time from either the digital mode or the anolog hands , you can choose one which is incorrect and try to change it.
Now to change the analog clock's settings , you would have a button which you can manually rotate and set the time, this is how you would be able to recognise that it's for the anolog time modification.
If you need to change the digital time , all you have to do is find out buttons that are present on the watch , and then try to change the time.
Note:- If you find a circled knob , remember that could only be for anolog time change as digital time is never changed using such knobs or screws , but have seperate button for that function.
In case you have any queries, feel free to get back.
Hope this helps ..:)
Jun 12, 2011 • Watches
9helpful
How do i change the date on my tag heuer formula 1? i know how to change the time. I went to change the time and in doing so it changed the date. when i went backwards it would not change back
You change the date the same way you change the time. The only difference being pull the crown out 1/2 way to the first click instead of all the way out.
5helpful
2answers
Time change Fossil JR 9120
i already found one link with all Fossil manuals.
Thank´s for your support.
6helpful
Need to change to Daylight savings time- automatic change did not happen
I need to change the current time. It does not change with daylight savings time, and I always have a problem setting it. Can you help me?
4helpful
Cannot change from 24 hour to 12 hour also did not change to daylight savings time
To change from 24 hour to 12 hour, you hold down the "Mode" button until it switches from 24 hour to 12 hour or vice versa. To change the time zone, you hold down the "Set" button until the time zone that you set it in flashes (like "LAX" on my watch). Then you press the "Receive/Start/Stop" button to choose the specified time zone you want. To set for daylight savings time ("DST" on the watch), after holding the "Set" button and having the time zone flash, you could press the "Mode" button. It will give you a few options for the daylight savings time (Auto, On, or Off). I chose the "On" option, which immediately changed for daylight savings time. If you manually want to change the time, you could hold down the "Set" button and keep pressing the "Mode" button until the time starts flashing on your watch, then pressing the "Receive/Start/Stop" button until you change it to the time that you want. You could also set the watch to beep or chime after pressing the set button if you wanted to know that piece. You hold down the "Set" button when you are done to get it to stop flashing. These instructions worked for my Timex T5G341 Universal Radio Control Watch. I hope this helps.
Top Kenneth Cole Watches Experts
Ngoro
john h
ADMIN Andrew
ADMIN Andrew
Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
