Xerox WorkCentre 4150 Black and White Copier Logo
Posted on Aug 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Our xerox workcentre 4150 is stuck in a self test mode. We have turned off the machine and unplugged it several times, and it keeps going back to the message Please wait....Machine self test in progress. What should we do?
Anonymous
Level 3:
President:
  • Master 2,072 Answers
  • Posted on Aug 13, 2010
Anonymous
Master
Level 3:
President:
Answers
2072
Questions
0
Helped
1109674
Points
5835
You will either have to take off the back cover and remove the memory battery. One of those round lithium batteries and reinstall it or go to xerox.com, download the newest level of firmware and load it to the machine.
You may also want to try turning the machine off. unplugging the hard drive and see if it works like that.If it works without the hard drive replace it. If all those steps do not work replace the main board.
Xerox workcentre 4150 not printing test page on windows 7
Hi Cnorini ,
Check this video and solve your problem.
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Xerox Printer Support
1helpful
Xerox Workcentre 4150. Paper keeps jamming in print engine area. We clear the jam and it jams again.
If your Xerox WC 4150 is displaying "Clear the Jam in the Print Engine" or constantly jams as paper exits the machine you should check and possibly replace the fuser actuator (part# 120N00534) This is the most likely cause, if however this does not fix the printer the next step may be to replace the sensor or fuser.
Here is a video that shows you how to check and replace the actuator. ItemInc.com has this part in stock and ships same day. Good luck, and thanks for using FixYa!
Xerox workcentre 4150 it say: System unavable do not power down until power down message comes up. Then when they power down and turns back on it comes up with same message. Can you tell me what to do....
This one probably relates to a failing CMOS battery 105N02093. First, though, you can unplug this battery for 30 seconds and try again. This is an inexpensive part, so start with the battery.
It could also be a defective hard drive 005N01086 or Main board 140N63141.
Whit
Item, Inc
Xeroxcopier
It varies from machine to machine. There are at least 6 differnt ways to access service modes that I can think of.
I need to change my Xerox workcentre 4150 toner cartridge. The old cartridge is stuck and I cannot get it out. Any ideas? Thank you. Russ thornock
You have to twist them clockwise and then counter clockwise. There is a locating pin they stick on in back, All I can say is twist and pull.
You can try opening the right side door and sliding a thin bladed screwdriver in there to assist in lostening it .
That is not uncommon and is frustraiting.
My workcentre 4150 is on my network and sometimes
Check and see if your using the PS driver for that machine, If so switch to the PCL driver. The PS one has been known to run slow.
1helpful
How can I reset the NIC on the WorkCentre 4150? I'm experiencing network configuration problems on the printer, and I was told a reset of the NIC would fix them. But I don't find in 'Tools' a command to...
  1. From the WorkCentre, enter the Tools mode. See the Related Items below for additional information. The Tools Mode screen will be displayed.
  2. Select [Software Reset] from the Touch Screen.
  3. Select the [Reset System Software] button. A popup window will be displayed warning that jobs on the machine may be lost and asking for a confirmation before the reset is performed.
  4. Select [Confirm]. The WorkCentre will reboot the system software.
Xerox WorkCentre 4150 Error code: 20-800/The machine cannot save the fax settings to memory. Xerox service is required to inspect the backup battery. Faxing is disabled, printing and all other machines...
One of 2 things.
EIther you have to enter the Fax User memory, Or the memory battery has failed and needs replaced.
Here is what the service documentation says.
(4150) During a power-off period, the machine has lost its user memory. Check that the backup battery, PL 1.10 Item 5 is holding its charge of about +3V. If necessary, install a new battery, PL 1.10 Item 5.
Multifunction restarts repetedly
That is usually a bad main board. You can try removing the memory and reinstalling it...that fixes the problem sometimes. Also unplug your network cable and turn it on...data present when turning on some xerox models will cause problems.
Main Board is part number 140N63141
Xerox 4150 Workcentre, when xeroxing and pringt copies are dark and gray. I have clean the the window but still grayish.
Sorry I didnt see your post a while back.
You shold call and have the firmware updated on that machine.
There are several firmware updates to the 4150 that resolve a lot of problems with the machine/.
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
