Samsung CLX 3160fn All-In-One Printer Logo
Posted on Apr 29, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Scanner was Locked, but now I CAN'T PRINT!
I unlocked the scanner, but now I can't PRINT! HELP ME!!!
Josh Lake
Level 2:
Habit-Forming:
New Friend:
  • Expert 126 Answers
  • Posted on Mar 29, 2016
Josh Lake
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
126
Questions
0
Helped
69784
Points
387
I the issue is nothing happens when you click Print or you get an error when clicking Print click the link below to see how you can fix this:
https://youtu.be/CpWjvJ1J9z4
If you need further help, I’m available over the phone at https://www.6ya.com/expert/josh_8e641fe76e154b02
MAHYAN
Level 1:
  • Contributor 1 Answer
  • Posted on May 05, 2008
MAHYAN
Contributor
Level 1:
Answers
Questions
Helped
549
Points
0
Unlocked the scanner, but now I can't PRINT! HELP ME!!!
Brother copier scanner mfc8480dn says SCANNER LOCKED what do I do?
Open the scanner top cover and you should see the lock/unlock switch on the right side(on the side where adf is). Make sure you set it to "unlocked" so it can move freely. If that doesn't help, there may be a broken gear on the scanner bar.
1helpful
3answers
Hi there I have a Uniden BC92XLT Nascar scanner, but some frequencies cannot be found. For instance the frequency range between 60 and 90 mhz is not on the scanner. How do I unlock those? Some of the...
Sorry, but there is no way to "unlock" or modify the frequency coverage of the BC92XLT or any other recently-manufactured scanner. Your only option is to purchase a scanner designed to include the frequency range that you are after. If you don't already have it, you can download and print the operating instructions for your scanner here:
http://www.uniden.com/pdf/BC92XLTom.pdf
Bill B
9helpful
2answers
Display says Scanner locked
There is a green switch located under the scanner area of the machine. You will also see a diagram of locked and unlocked padlocks. Just slide the switch to the unlocked position. Hope this helps.
SCANNER LOCKED IS ON THE DISPLAY SCREEN I HAVE CHECKED THE GREEN BUTTON UNDER THE PAPER TRAY AND THAT IS SET TO UNLOCK. WHEN I TRY TO PRINT THE DISPLAY SCREEN SAYS SCANNER ERROR AND THE SCANNER LOCKED
Hi, what you want to do is, first; (shutdown) your Scanner, next (shutdown) the computer. Disconnect the scanner, and unplug it from the outlet. Disconnect scanner cables from the computer; Note: do not change anything on the computer. Reconnect cables to the computer. Plug scanner back into the power outlet; turn on computer, turn scanner on. This may clear the (Freeze); but the (Error) might appear again. Thanks paul7of9
All my channels are locked out on my scanner
The manual for your scanner doesn't list any type of global unlock procedure. Acording to it you will have to manually select each locked channel and press the L/O key. This should change the display from L/O to l/o.
Need the manual? You can download/print it here:
http://www.scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/PRO-97_OwnersManual_ome20-527.pdf
2helpful
2answers
Scanner locked - unlock scanner
To unlock a scanner open it where you would put cartridges in and look for a red or green colored tab hanging down. There should be a little picture of a padlock. You can switch it from lock to unlock. It's kept locked to protect the scanner during shipping.
Hope this is helpful...
Scanner locked.
Normally that is an issue with the ribbon cable from the scanner to the main board if the latch is in the correct position.
I would securely reseat that cable, bias it somewhat upward.
Check the ends of that ribbon cable to be sure a portion of the silver print isnt pealed back.
No reset code for that. The scanner may have failed also. The sensor inside the scanner may be bad.
You can try going to the Xerox.com site under drivers and downloads and load the newest firmware. But I doubt that is an issue.
Only other thing i could think of would be the scanner not returning to the full home position due to an obstruction.
Or the scan head itself being out of the rail latch, or even the end of the scan head could be broken, not scanning straight.
11helpful
2answers
Lexmark x5150 scanner locked
Unlock Scanner message
The scanner is locked. to unlock it
1. Press Power to turn the All-in-one off.
2. lift the scanner unit until the scanner support holds it. To the left and beside the scanner support is the scanner lock
3.pull the scanner lock toward you to unlock the scanner.
4. close the scanner lid.
5. power on.
5helpful
3answers
3helpful
Dell A940 - Unlock Scanner then press power
See
http://support.dell.com/support/edocs/systems/a940/a940en1.pdf
Page iv identifies the location of the scanner lock
Page 44 contains the following
• You unlock the scanner bed. For help locating the scanner lock, see the picture of the printer on page iv.
Page 51 contains
The scanner is locked. To unlock it:
1 Press Power to turn the printer off.
2 Use both hands to lift the printer (scanner unit) until the scanner support
holds it open.
To the left and beside the scanner support is the scanner lock. For help, see
page iv.
3 Pull the scanner lock toward you to unlock the scanner.
4 Using both hands, lift the printer (scanner unit).
5 Push and hold the scanner support back.
6 Lower the printer (scanner unit) until it is completely closed.
7 Press Power to turn the printer back on.
Top Samsung Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
