Sony Ericsson K608i Cellular Phone Logo
Posted on Aug 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Insert sim problem tell me solution? and my pone sim regidtrence it brok there.
Anonymous
Level 3:
President:
  • Master 1,118 Answers
  • Posted on Aug 13, 2010
Anonymous
Master
Level 3:
President:
Answers
1118
Questions
0
Helped
276554
Points
4142
Try with another sim card, clean the sim connector of your phone, reset you phone to Factory Setting (default) using 12345. If you can open it, clean the mobile thoroughly using iPhone solution. This problem is caused by Firmware problem and Hardware problem as well.
OR:
New Software Reinstall in the Phone
I used code *7465625*638*7337# on samsung star 3 it tells me insert sim and i have also inserted sim but still it tells me insert sim plzz help me
Make sure the sim connector is clean. Clean contacts with a pencil eraser. Make sure there is no dirt or debris on the inside before reinserting.
Hope that helps!
tip
How to Unblock Network lock of SAMSUNG SGH-J700
SAMSUNG SGH-J700 UNLOCKING:
1- Power on pone ,, type : *#7465625#
you will identify which code is active , which is inactive
2- Remove battery ,, Put your sim card , not all of it ,, just to prepare it to be full inserted , put your battery back and power on pone ,, you must see " insert sim" not "invalid sim.."
3- type : *2767*3855#
your pone should restart after 1 min ,,
now ,, and before it restart , push your sim card ,,without removing battery
4- your pone should work and accept the sim card ,, but if you check locks you will find that your pone is still Locked
5- now type : *7465685*638*00000000*00000000#
your UNLOCK CODE is 00000000 now ,
6- now , back to Locks table with : *#7465625# ,, and for each active code you can disable it ,,,Here details :
* Disables CP lock : #7465625*27*00000000#
* Disables Network lock : #7465625*638*00000000#
* Disables SIM lock : #7465625*746*00000000#
* Disables SP lock : #7465625*77*00000000#
* Disables Subset lock : #7465625*782*00000000#
on Jan 21, 2010 • Cell Phones
No sim card message on i pone
Also check whether you're using the correct type of sim card for your phone. GSM vs whatever. Depending on what country you're posting from you may have to check for local solutions.
1helpful
How to transfer contacts from one samsung phone to another samsung pone
If your Samsung phone carries a SIM Card, copy all contacts from phone to SIM and insert it to the new phone. If not, then you have to copy each contact and save them to your new phone.
Thank you for visiting FixYa! We answer your concerns promptly for FREE. Please spare a few seconds to click on YES button in return. Have a good one!
Jul 15, 2011 • Cell Phones
2answers
It is telling insert sim
Insert a SIM, or, if it has a SIM, remove and reinsert the SIM. Usually requires removal of the battery.
I have an iphone with no sim card in it but the pone is disabled due to a passcode issue. how do i solve it?
you need to call att to give you the code just tell them you bought the phone and need the code if your nice to them they will give it to you
4helpful
2answers
It Says No SIM Card Inserted !
I have the same problem. the difference is that since the beginning it says "no sim card insted" and i tried with two sim cards (vodafone both) and none of them work. what can i do?
3answers
Insert sim
try installing some other sim. if the problem persists, then the problem is with your phone. reset the phone to factory settings. if the problem is shown for the particular sim alone then you should have either damaged the sim physically or electronically or dropped in water. change the sim then
2answers
UNLOCK CODE
my handset is Samsung SGH-100.it hangs when i make/receive a call and finally switch off automatically.what should i do???
Dec 10, 2007 • Cell Phones
Top Sony Ericsson Cell Phones Experts
Sean Wright
Sean Wright
Kolbrun...
ZJ Limited
ZJ Limited
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
