Invicta Dragon Lupah 2094 Wrist Watch Logo
Posted on Aug 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am looking for watch straps with the quick release pins for a dragon lupah
Janelle Schoonover
Level 3:
  • Master 842 Answers
  • Posted on Aug 13, 2010
Janelle Schoonover
Master
Level 3:
Answers
842
Questions
Helped
457500
Points
2634
This is the best place and probably the ONLY place you will find that specific type of band. Best wishes.
http://www.invictawatch.com/support_files/service_center/ServiceCenter.htm
I have an original Invicta Men's Lupah w/ chronograph. Which of the 3 buttons on the side of the case is for setting the date? I can't seem to figure out how to set/reset the date. Thanks in advance...
If your lupah has a screwdown crown (middle button), you need to unscrew it. Pull out the middle button 1 click (it should have 2 clicks...if it's all the way pulled out, then you have gone too far) and turn the screw counter clockwise. Some model's you have to give them a couple good turns to adjust a single day, so don't give up if you move it a quarter turn and nothing moves. Once done adjusting, just push the crown back in and lock it down (lock down crown isn't a necessity. It is rather a means of keeping water at pressure from entering your time piece. So don't freak out if your model doesn't have a screwdown crown. Not all of them do). Best of luck to you!
How do you set the watch
Go to http://www.invictawatch.com/new/product/search.php?CAT_REF_NBR=7&prn=2095#2095 (this should be part of the "collections".
Click on the tab maked "manual" and you should find the information you need.
My invicta 2093 watch keeps stopping
The 2093 is listed as a quartz watch and may need a new battery. Any watch shop or jewelry store should be able to replace the battery and caseback gasket for about $8. The gasket keeps water out and should not be reused.
Its broken and I need a replacement strap. I order one from Invicta three months ago and still haven't received it.
Have you tried your local watch shop?
Unless the strap has an unusual fitting, a standard type should do the job.
4helpful
I can;t figure out how to change bands on my baby
It is easy for anyone who did it, but for the first time can be quite tricky. You have to take small screwdriver or pocket knife and insert the blade between strap/band and watch case lug (where the band is attached to watch), then pry it inwards applying some pressure. It will release the spring lug and the band will come off. You may need to repeat this on the other side of band as well. Rate me,plz.
How do i set the time on an Invicta Lupah mens watch with three subdials
The Lupah has a chronograph so dont worry about the sub dials while your setting the time. Pull the crown out to the first position and set the time. For the date pull out to the second position and set the date.
To set the chronograph sweep arm pull the crown out and press and hold down the start button. The sweep arm will move into position. Stop it on the 12:00 or 0 position.
Invicta Lupah crown replacement?
If there is no problem with the stem then you can just screw it on. I suggest using a thread lock to insure a good fit. Start by taking the back off and hold the stem in place with a pair of needle nose pliers. Be sure to start by turning the crown in the reverse direction so you dont cross thread. Once you feel it hit the beginning of the thread you can turn in the on direction.
I always recommend having this sort of service done by a watch maker/technician who can reseal the watch and pressure test it to be sure it is still water resistant.
Invicta Lupah #2094
The Lupah is a quartz movement so try having the battery replaced.
Top Invicta Watches Experts
Ngoro
john h
Are you an Invicta Watch Expert? Answer questions, earn points and help others
