I can't get the TV to respond to anything other than on/off. I have tried from the side buttons and from the remote. I can turn it on and off but no menu, +/-volumn,+/- channels, entering channels by numbers....none of the buttons on the remote do anything except the Power button. It comes on and reads ANALOG TV as usual then identifies the Channel A 47 with the word Mono underneath.... It plays the channel just fine but that's it..... just that one channel.... Then last thing I recall having done was gone into the TV Menu and set the channels... Could I have screwed something up there? Is there a way to reset the thing back to factory defualts? same problem, remote will not work other than off and on; buttons on tv will not respond; tv is on one channel with little volume. the volume will not increase or decrease.
You need a new control board for your tv...
Thank you
COmputerrep
Check this site for the control board
http://shopjimmy.com/
SOURCE: iLO LCD Color HDTV does not change channels / volumn...just turns on/off
It's unlikely that a setting you changed in the user menu would have locked out both the remote and the panel.
It sounds to me like the micro has gone bad. One other option, is a stuck or damaged button assembly. Corrosion on the button board can lock the micro.
shopjimmy.com you need a new control board easy fix diy
This particular model of tv has a problem with the control board.
This is a common problem with this unit. You can find control boards on EBay, or through a local technician. Please refer to our online technician list for a professional near you.
Good luck :)
Where and how do I get & replace the control board?
Where and how do I get and replace the power supply?
