Resolution Suggestion One:
# Test your Internet connection to Windows Update.
A simple solution but one that works in many circumstances!
Test to determine if your Internet connection is preventing you from
reaching the Windows Update Web site. To do this, visit the following
Microsoft Windows Update Web site to determine if you can download the
Iuident.cab file:
http://windowsupdate.microsoft.com/v4/iuident.cab
If a file download dialog box appears, the problem is not with your
Internet connection. Click Cancel. If you cannot connect to this link,
and you receive a "Page Cannot Be Displayed" error message, your
Internet connection is preventing you from reaching the Windows Update
site.
I TRY THIS OPTION AND I HAVE NO PROBLEM
Resolution Suggestion Two:
# Reconfigure or update your firewall program.
Reconfigure or update your firewall program so that Windows Update is
not blocked, and then try to update your computer again by using
Windows Update. For information about how to reconfigure or update your
firewall program, see the documentation that was included with the
program, view the Help files for your program, or contact the
manufacturer's technical support department.
e.g It my mean Opening TCP/IP 443 in both directions for this process: %windir%\system32\svchost.exe
I DONT HAVE A FIREWALL PROGRAM.
Resolution Suggestion Three:
# Remove Windows Update entries from the HOSTS file.
To remove Windows Update entries from the HOSTS file, follow these steps:
-Click Start, point to All Programs, point to Accessories, and then click Notepad
-On the File menu, click Open.
-In the Files of type box, click All Files.
-In the Look in box, locate the following folder:
C:\Winnt\system32\drivers\etc\
-Double-click to open the hosts file.
-Remove any lines that contain entries for Windows Update (http://v4.windowsupdate.microsoft.com).
-On the File menu, click Save.
-Close Notepad.
I have seen the 0x80072EFD error resolved by this tip many times...
HERE I AM... I DON'T HAVE A HOSTS FILE... I NEED TO STOP HERE
AND SOLVE SOMETHING?
WHAT HAPPEN WITH THE NEXT SUGGESTIONS?
I TRY THEM ALREADY BUT THE PROBLEM IS STILL THERE.
I DON'T HAVE SPYWARE... I ALLREADY SOLVE THAT PROBLEM.
Resolution Suggestion Four:
# Run the IPCONFIG /FLUSHDNS command.
To run the ipconfig /flushdns command, follow these steps:
-Click Start, and then click Run.
-In the Open box, type cmd, and the click OK.
-At the command prompt, type the following command, and then press ENTER:
ipconfig /flushdns
Close the command window.
Resolution Suggestion Five:
# Add Windows Update addresses to the trusted sites list.
To add Windows Update addresses to the trusted sites list, follow these steps:
-Open Microsoft Internet Explorer.
-Click Tools, and then click Internet Options.
-Click the Security tab, and then click Trusted Sites.
-Click Sites, and then click to clear the Require server verification (https
for all sites in this zone check box.
-In the Add this Web site to the zone box, type each of the following addresses, and click Add after each address:
http://Windowsupdate.microsoft.com
http://V4.Windowsupdate.microsoft.com
https://v4.Windowsupdate.microsoft.com
http://Download.Windowsupdate.com
http://V5.Windowsupdate.microsoft.com https://v5.Windowsupdate.microsoft.com
-Click OK to close all Internet Options windows.
Resolution Suggestion Six:
# Add Windows Update addresses to the proxy settings exceptions list.
If your Internet connection uses a proxy server, add the Windows Update
sites to the proxy settings exceptions in Internet Settings. To do
this, follow these steps:
-Open Internet Explorer.
-Click the Connections tab, and then click LAN Settings.
-Click Advanced, and then type the following text in the Exceptions text box (all in one line):
windowsupdate.microsoft.com;v4.windowsupdate.micro soft.com;
download.windowsupdate.com
Note If you are running third-party proxy or firewall software, see
your product documentation for information about how to add these sites
to the exception list for those applications.
Resolution Suggestion Seven:
# Change the MTU setting on your router.
Yours ISP's MTU for their connection may not be correctly setup on your Broadband router and/or your computer.
Please contact your ISP's support for more assistance on this. However the following articles may be of help:
http://www.microsoft.com/windowsxp/using/networking/
learnmore/ppoe.mspx
http://support.microsoft.com/default...b;en-us;283165
Resolution Suggestion Eight:
# Configure Norton Internet Security 2003.
Norton Internet Security 2003 may be blocking Windows Update. try this:
-Open the Norton Internet Security 2003 Application
-Click on "Norton Internet Security" button located on the left side
-Click on "Personal Firewall" located on center
-Click on "Configure" button on bottom right side
-When dialog box appears, click on "Program Control" tab
-Scroll down and find and click on "Microsoft Generic Host Process for Win32 services"
-Then click on "Modify" bottom at button of scroll box.
-When dialog box appears, click and choose "Permit" button
-Close all boxes and close Norton.
-Reboot your computer.
