SOURCE: Fabric Softner section won't fully drain....
take your soap draw out pull the fabric softener tub out wash leave all of your soap draw in a bucket of hot water scrub with a brush this should clean a small hole which lets your conditioner out simply fix common fault m8
SOURCE: fabric softner
Remove the dispenser tray. Inspect the area just above the fabric softener portion of the dispenser. There should be a series of holes where water feeds into the tray during the rinse cycle. Sometimes these holes become clogged with fabric softener residue. If the holes are clogged, water will never dispense the fabric softener out and it will stay in the tray. If you take some cotton swabs and meticulously clean all the holes out, I bet your problem will go away. Let me know if this was helpful to you.
SOURCE: Fabric softner still in draw when wash finished
There is a blockage in the dispenser that is causing the prob.
Remove drawer from dispenser, and thoroughly clean every part of it, taking all the pieces out to do it.
To test it is working, put it back together, and before you put it back in, fill the conditioner compartment with water until it starts to overflow, turn water off, and the remaining water should continue to run out, until it is empty, if it does not , then it is still blocked.
Plz rate my solution.
Thanks.
SOURCE: washing power drawer, the fabric softner section
Pull the drawer out as far as it will come and then grasping it firmly, give it a good tug towards you, this will free the drawer to enable you to thoroughly clean every piece of it, particularly the conditioner parts of it.
Get a piece of wire with a bend on the end, and poke it in to all the holes in the top of the dispenser compartment, this will clera any blockages there.
Plz rate my solution, and feel free to leave any comment.
Thanks.
SOURCE: fabric softner does not empty
I had a similar problem and removed the complete dispenser drawer and washed it in with hot water. The small inner cups for the fabric softener and bleach should be removed and the hot water directed into the small "stand pipes" on the back side of the covers. It appears the fluids in the cups are siphoned out and if the pipes are clogged at the bottom there will be no flow. Also is the plate is not fully seated, the siphon effect is will not work.
Also, my wife said she does not use the cheaper brands of fabric softener anymore because we think that might have caused some of the clogging.
As a side note, if you remove the top of the washer, there is an adjustable dial where you can fine tune the amount of liquid dispenced. You can try adjusting that too. I think my final fix was to clean the back side of the face plates inside the dispenser and ensure they are fully seated to allow the proper siphon effect.
