Cameras Logo
Posted on Aug 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We have a Technika SH-8360, and it appears that the image quality has decreased dramatically, and now the pictures are of a lot lower quality and much grainier than before. What would cause this? Would this have anything to do with the camera losing it's megapixels?
Anonymous
Level 3:
Brigadier General:
  • Master 11,967 Answers
  • Posted on Aug 12, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
11967
Questions
0
Helped
2200737
Points
38521
Cameras don't lose megapixels but users can change the settings for them. Go into the menu and see if your camera is set for the maximum number of megapixels and the highest picture quality.
2answers
How to improve quality of pring photos
page setup,the most dpi it can handle or get a photo printer
2answers
How to improve the quality of pring photos
Use Epson Photo Paper, and set your printer to "best" quality.
I could help you better if you would:
1. give model of printer
2. tell me what paper you're using
3. what the problem is with your photos.
3answers
How to enlarge a picture that is scanned or copied? When i scan or copy a picture it is too small and I want to enlarge it in order to view it better.
hi
Open an image. Go to the Image Menu and select Image Size. This is where you can change an image’s resolution and print size (width and height). The following Image Size dialog box will appear:
Notethat the width and the height of the image as you view it on yourmonitor is not necessarily representative of the image’s actual widthand height—i.e., the size it would print out at (print size).Average monitor resolution is 72 dpi. If you view a 72 dpi image at100% in Photoshop, chances are that it will appear on your screen inits actual print size. However, this is not true when viewing a 300 dpiimage. A 300 dpi image viewed on-screen at 100% will be enormous. Don’tget tricked into believing that what you see on your monitor is whatyou’ll get when you print or place the image into another application.The best way to determine what your image’s actual print size will beis through the Image Size dialog box.
When the Resample Imagebox is checked, any changes you make to an image’s width or height willnot change the image’s resolution, and as such, any changes you make toan image’s resolution will not affect the image’s width and height.Keep in mind, however, when you increase width and height, orresolution, with the Resample Image box checked, you are adding pixelsto your image. These pixels don’t actually exist so Photoshop mustcreate them. As such, you will succeed only in degrading the quality ofyour image.
If you want to increase an image’swidth and height, or resolution, then uncheck the Resample Image box.Now any changes you make to the image’s width and height will changethe image’s resolution, and vice versa:
  • If you decrease resolution, the width and height will increase.
  • If you increase resolution, the width and height will decrease.
  • If you increase the width or height, the resolution will decrease.
  • If you decrease the width or height, the resolution will increase.
Thebest way to increase the width and height of a scanned image is to scanthe image in at a high resolution (about twice what your finalresolution should be), and with the Resample Image box unchecked, decrease the resolution. Once the image width and height is where you want it, you can then check the Resample Imagebox and type in the resolution you want if the resolution is too high.At this point, as long as you don’t increase resolution, or width andheight, your image quality will not suffer.
Hi, i have a TECHNIKA SH-8360 digital camera and took some pics without the memory card in, is it poss to somehow transfer pic to computer without a memory card?
that depends if your camera has a bit of built in memory than you can if in doesent then you can't good luck:)
Mar 28, 2010 • Cameras
1helpful
2answers
Manual for technika sh-340t
When i turn my Technika camera on it turns its slef of in 3seconds and i have new battries why does this happen.?
Aug 28, 2009 • Cameras
2answers
Image Quality decrease
Um ok. first off, chill with the images being described in inches. The DSC-S40 is way too simple to get lost with. You only have 2 options to play with. One is the resolution which you want to be as high as possible unless you have some special reason for it not to be. Two is you have 2 image quality settings to choose from(Fine and Standard). choose "fine" of course for best results. yes the files size will be a bit larger, but you get the best possible image. Remeber, this is considered a cheap camera, so you want the most it can offer.
Now about the file size anomalies. Dont worry about it. Here is the only conclusion I can come up with that sounds logical. .JPG and most "compressed" image types will never be the same size if taken from a camera unless the same exact picture is shot 2 times in a row very fast witout the camera moving. files size on a compressed image depends on the amount of color variations the camera has to render into a file. The more color variations, the more data the .JPG file contains. It is natural for file sizes from a camera to differ. If you set your camera at 4M and take a picture, and then you set it to 3M and try to take the same picture again thinking it will save space, in theory this is true, but remeber how "compressed" images are rendered. You may have had only the slightest difference of light change on the next pitcture you took . This can have a significant impact on the file size, and can result in a lower res image being bigger in file size than the higher res image. Now, if you are talking a huge difference like 3M@1500kb yet 4M gives you 500kb, then you either have it set to "standard" quality, or you are really lost in this stuff.
But anyway, I hope this is plenty of info. And makes plenty of sense to anyone who understands compressed images.
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
