SOURCE: No heat in 91 Cadillac Sedan Deville
I would beleive more that you have build up in the heater core. Try taking loose the heater hoses from the block and use a water hose to spray into one of the hoses letting it come out the other hose then switch hoses with the water hose and keep reverseing for 2/3 times each hose. sounds like stop leak may have been used in a prior time and may be blocking water flow.
Good luck,
Lugnut61
SOURCE: 1999 Cadillac Deville Heater Blower motor has
make a jumper cable up from lamp cord (from any Hardware store) and power up the blower motor from the battery
SOURCE: wher is the blower moter located at to a 2002
The blower motor is located under the glove box. It is a very difficult procedure to replace. The blower motor has six 7/32 size screws, two of which are hidden and one, the closest to the firewall, will require a 1/4" drive, and swivel. I removed the glove box in order to put the replacement blower motor in. It takes a little extra time but allows more room and saves your back. Get a diagram off the internet of how to remove these things. Plug in the new blower motor and test it before you just install it! My biggest fear installing the new blower motor was that it took a lot of force to get it back in on an angle. Almost thought that I was going to crack or damage the fins on the cage. It takes force but just be careful.
